Author Topic: Heater case markings  (Read 4029 times)
Offline Chris
« on: February 24, 2014, 08:51:56 PM »
I just rebuilt my heater case for my 19 June 64 convertible with AC. I came across some white matkings on the top corner of the heater case and wondered if anyone has seen these before? It looks like "Y4FC". Could this be for 64, June, third week...something like that?
It's the original heater box, no cut out for the resistor on the front and marked with FoMoCo script in oval with a Y1 to the side.
« Last Edit: February 24, 2014, 09:07:44 PM by Chris »
Offline suskeenwiske
  • 214-347-3628
Re: Heater case markings
« Reply #1 on: February 24, 2014, 09:20:58 PM »
I have several parts of various Heater Boxes; all have the Date Code stamped in white on the top and all in different locations. Yours looks just like the ones I have.
Nice job by-the-way! How did you get the case to look so nice?
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline Chris
« Reply #2 on: February 24, 2014, 10:05:48 PM »
I sprayed the whole thing down with Griot's rubber cleaner and wiped clean with a cloth. There was lots of rust residue on the inside, the outside was just a bit dirty.
Offline Chris
« Reply #3 on: February 24, 2014, 10:11:55 PM »
Here are some pics of the "before" cleaning. I think the fan is original (shown repainted). It's marked Vernco Corp in an oval.
« Last Edit: February 24, 2014, 10:14:03 PM by Chris »
  • 214-347-3628
« Reply #4 on: February 24, 2014, 10:27:34 PM »
Did the Rubber Cleaner take the rust off of the Bracket Rivets too? Thanks for the photos and great Water Color Painting by-the-way...children's treasures.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline Chris
« Reply #5 on: February 24, 2014, 10:36:26 PM »
The rubber cleaner did a good job on the case, inside and out, getting rid of all dirt and rust residue. The rivets were already pretty clean. The brackets are hard to clean being attached to the case. Best to tilt the case on the side and use a brush and cleaner to keep the harsher cleaner off the case. There are probably many speciality cleaners for rusty parts, but I always have heavy-duty carb cleaner on hand and it strips off rust and paint pretty well, especially with a little brush. You'll have to use something stronger for rust on the metal parts, like the carb cleaner. Take the metal parts off and clean separately. The rubber cleaner is good for the case itself.
The picture was done by my 5 year old:).
« Last Edit: February 24, 2014, 10:41:54 PM by Chris »
Offline kutzoh
  • Gold Level Subscriber
« Reply #6 on: February 24, 2014, 10:46:44 PM »
Chris-
    I have a similar marking on my plenum, late June '64 build. Don't remember seeing anything on my heater box though.
http://s642.photobucket.com/user/kutzoh/media/IMG_1439.jpg.html
Greg
Offline Chris
« Reply #7 on: February 24, 2014, 11:02:58 PM »
Greg,
Thanks. That matches up with my heater box markings, Y4FC, and both our cars are scheduled build dates of June 64.
« Reply #8 on: February 24, 2014, 11:38:40 PM »
I just rebuilt my heater case for my 19 June 64 convertible with AC. I came across some white markings on the top corner of the heater case and wondered if anyone has seen these before?...........
That is the typical one (yes seen these many times before)
Have seen them in white and yellow depending on year
There is also a very different stamp (similar pattern of letters and numbers)  that is larger and has dashes '-" between the digits Possibly from a second vendor/subcontractor/provider
« Reply #9 on: February 25, 2014, 12:16:45 AM »
I have three fans that I had plated (I don't like rust) and one has the Vernco markings, very faint, you can see part of the oval with  letters N and R only. The other two a have four embossed stress veins instead of five on the flat mounting surface and are stamped TORRINGTON and 408 AIROTOR. I think that all came from 65 or 66 cars as the associated motors are three speed (two wire). I cannot be certain that they are factory original or service replacements.
Much of this is documented in the library.
http://concoursmustang.com/speegle/Articles/Article_Heater_Motor_Feed_Cable_Part_1.pdf
http://concoursmustang.com/speegle/Articles/Article%20-%20Heater%20Motor%20Feed%20Cable%20Part%202b.pdf
« Last Edit: February 25, 2014, 12:27:48 AM by jwc66k »
Offline livetoride60
« Reply #10 on: February 25, 2014, 12:09:38 PM »
Checked and my fan has the 4 stress veins with stamped TORRINGTON and 408 AIROTOR markings.  This is for an Oct 64 San Jose car.  Can't guarantee it is original, but had original looking rust.  :)
« Last Edit: February 25, 2014, 12:17:37 PM by livetoride60 »
Offline Chris
« Reply #11 on: February 25, 2014, 07:19:50 PM »
When I removed the fan motor, it was marked with 1964 (that I could make out, see pic), had the part number, and the FoMoCo oval. It looked like it had never been removed. I'm guessing the Vernco Corp fan is original for my Dearborn 19 June 64 car. Looks like there could be differences in the fans used by plant.
« Last Edit: February 25, 2014, 07:21:46 PM by Chris »
Offline ChrisV289
« Reply #12 on: February 25, 2014, 09:25:42 PM »
When I redid my heater box last year, here are the markings I found.  Can't read them though
Here is the stamping on the fan motor as well, Sept 28, 1964:
« Last Edit: February 25, 2014, 09:29:49 PM by ChrisV289 »
2009 V6 Mustang Coupe
« Reply #13 on: February 25, 2014, 11:01:10 PM »
Happened to glance at a 66 AC unit I have, and it's fans are stamped TORRINGTON as well, and also 3 13/16" AIROTOR.  Obviously Torrington must have been an OEM vendor.
