Author Topic: heater motor wiring location  (Read 2874 times)
Offline Panther
  • Bronze Level Subscriber
    • Early Mustang
« on: February 25, 2016, 11:46:42 AM »
Hi There,
i'm finalizing my heater restoration and i got a question concerning the location of the heater motor wiring.
The article about heater restoration shows a two wire motor with the cables located on top (11-12 o clock):
Heater Motor Feed Cable Part 2b
Virginia Classic Mustang shows it the different way:
Charles restored three wire heater has the three cables located on bottom side (5-6 o clock)
My 66 heater motor showed the same situation as the article (See attached picture).
What is correct, especially for the two wire version?
Have a nice day!
Paul
Paul
6R07C214274
65A 8 D6 11F 71 6 6
Certified MCA Judge 1964.5-1966
Offline WT8095
  • Dave Z.
Re: heater motor wiring location
« Reply #1 on: February 25, 2016, 02:07:38 PM »
I see only two wires from the motor. The ground cable from the cylinder head to the firewall is visible in the photo - is that the third wire you're referring to?
Dave Z.
Offline Panther
    • Early Mustang
« Reply #2 on: February 25, 2016, 03:56:03 PM »
I didn't post the pic of Charles three wire heater...here it is:
(Charles, hopefully you don't mind if i post the pic here)
Paul
6R07C214274
65A 8 D6 11F 71 6 6
« Reply #3 on: February 25, 2016, 04:06:35 PM »
Probably best to be asking what type of heater motors others with late '66 SJ cars have.
The heater motor in the K code is period-correct for when/where that car was made.
« Reply #4 on: February 25, 2016, 05:11:04 PM »
Probably best to be asking what type of heater motors others with late '66 SJ cars have......
Easy enough to provide
Paul's car is 6R07C214274  - here are other examples - same plant about the same time (ignore some of the PO's choice to black rattle can stuff :(
6R07K2040xx
6R09C2088xx
6R07A2163xx
6R07T2265xx
Offline Panther
    • Early Mustang
« Reply #5 on: February 25, 2016, 05:46:17 PM »
Thank You very much! That'll help a lot!  :)
Interesting to see, that Metuchen is different to San Jose  ;)
Paul
6R07C214274
65A 8 D6 11F 71 6 6
Offline mjd 65
« Reply #6 on: February 25, 2016, 05:48:53 PM »
If I recall correctly, the three wire motor was used on the 64-1/2 and early 65s with the center "off" blower switch.  Later 65s and 66s use the two wire motor.
Mel
Offline Panther
    • Early Mustang
« Reply #7 on: February 25, 2016, 06:19:38 PM »
exactly!
Jeff could You look up what would be correct for a  dearborn car, build on 10 of may 1964? Would  be great :)  a friend asked me what would be correct for his car.
Paul
6R07C214274
65A 8 D6 11F 71 6 6
« Reply #8 on: February 25, 2016, 06:23:24 PM »
The K code I restored is a San Jose car.
Offline Panther
    • Early Mustang
« Reply #9 on: February 25, 2016, 06:28:28 PM »
I made a mistake, i meant the last picture of Jeffs pics but its not a Metuchen car, it's a late 66 san jose six banger (wrong "T"  ;D ) sorry for the confusion!
Paul
6R07C214274
65A 8 D6 11F 71 6 6
« Reply #10 on: February 26, 2016, 11:50:36 PM »
Easy - three wire - one being a ground
Have three wires being used on early 65 Dearborn built Mustangs into Sept 64 at least (just a quick look)
Offline Panther
    • Early Mustang
« Reply #11 on: February 27, 2016, 06:03:38 AM »
Sorry, i meant the loaction of the wires. are they located on the upper side or the  down side?
Paul
6R07C214274
65A 8 D6 11F 71 6 6
« Reply #12 on: February 27, 2016, 03:51:36 PM »
Four examples with the wire exiting the heater motor at the same location
« Reply #13 on: February 27, 2016, 04:08:46 PM »
The answer is yes.
6R07K2040xx
6R09C2088xx
6R07A2163xx
6R07T2265xx
It makes no difference as long as you finish as you started.
