Author Topic: Clear coat on Aluminium chromed trim  (Read 2614 times)
Offline 66RavenGTCoupe
« on: December 14, 2014, 06:12:54 PM »
Hi All,
Helping a friend with his '69. He got his aluminium headlight bucket trims chromed but was told that he needed to get them coated to stop them dulling off.
Can anyone tell us what this is?
Daniel and Greg.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: Clear coat on Aluminium chromed trim
« Reply #1 on: December 14, 2014, 06:30:24 PM »
Aluminum trim was anodized or 'bright dipped'.
« Reply #2 on: December 14, 2014, 07:33:19 PM »
Not sure why chrome plating would "dull off"  If that was an issue one would see allot of bumpers being clearer
If he did "chrome" those curved pieces then I'm guessing he doing the lower grill and hood trim since only having half of the trim done
Sorry - I've never tried to get aluminum chrome plated.
« Last Edit: December 14, 2014, 10:41:11 PM by J_Speegle »
« Reply #3 on: December 14, 2014, 10:27:01 PM »
Or anodizing was mistakenly referred to as chromed.
Offline GD64
  • Bronze Level Subscriber
« Reply #4 on: December 16, 2014, 07:42:10 AM »
Or the pieces were sanded and polished.
64 Galaxie (54A)
RHD Export Model
390 4V, Dual Range Automatic
Oaville, Ontario Assembly plant.
« Reply #5 on: December 16, 2014, 02:03:44 PM »
Yes more likely and once aluminum was polished it needs to be protected from oxidizing. A clear coat paint will flack off eventually and doesn't protect nearly as well. If regular anodizing is done it will severely dull down the shine . "Brite dip anodizing doesn't dull the shine nearly as much and holds up well over many years. Brite dip anodizing is a special process different then regular anodizing and not a process that a lot of platers are set up to do. People get the two confused all of the time and are dissatisfied  when after getting their shiny part regular anodized it comes back dull. Brite dip is what the car manufacturers use on shiny aluminum trim typically.
« Last Edit: December 16, 2014, 02:06:47 PM by Bob Gaines »
Offline ddonzella
« Reply #6 on: March 30, 2015, 12:29:20 PM »
If it's aluminum polished to look like chrome then buy a quart of Shark Hide from a marine supplier or Eastwood. It clear coats aluminum with a polymer liquid that will keep it from dulling. However you must follow the directions precisely or you will have a rainbow type sheen on the treated polished aluminum surface.
