Author Topic: Interior upper quarter panel vent grills re chrome ?  (Read 3586 times)
Offline gimpystoy
« on: December 14, 2014, 03:58:11 PM »
Has anyone had success re-chrome the interior upper vent panels vent grills? I'm thinking a alternative may be emory sanding,Eastwood chrome paint.
Thoughts, experience, please.
Gimpy
« Last Edit: December 17, 2014, 06:13:36 PM by carlite65 »
67 C code Metuchen, May "67" build 289 C4
Offline Fastback2013
Re: Interior upper quater panel vent grills re chrome ?
« Reply #1 on: December 16, 2014, 03:56:23 PM »
Hello Gimpy,
I have/had the same problem.
I have searched (and hopefully found  ???) a firm, who didn't saw any problem(s) with re-chroming those parts.
Last week I picked up the chrome trims of the folddown rear seat of my fastback.
I think they came out pretty well?
In attachment you find the original part and the same re-chromed part.
I think it is always the best that you can re-use all your existing parts in stead off buying new/aftermarked products, with a possibility that they doesn't fit that quite well ::)
He promised me that I could have my other parts till the end of this year... so I must have patience for another +/- 14 days  ;D
If you want, I will post the pictures when I received them.
Personally, I think that you could do more harm with painting etc., when you are able to fully watch every detail when sitting inside your car... just a thought ...
Kind regards,
Jeroen
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
Offline gimpystoy
« Reply #2 on: December 16, 2014, 04:54:55 PM »
They came out beautifully .
So I have to ask. Where is shop that did work, please
Gimpy
« Reply #3 on: December 16, 2014, 05:31:36 PM »
It is done by 'Chromage Central' in Ghent/Belgium.
An 'old school' craftsman...
Not knowing where you live, but not that difficult for sending your items to Belgium?
If you want his email address or phone number, just ask.
Kind regards,
Jeroen
Fastback GTA
built on 01/12/1967
« Reply #4 on: December 16, 2014, 06:59:25 PM »
Gimpy
Upper vent panels (pot metal) and folddown trim (steel) require two different techniques of chrome plating. The pot metal is much harder to do and the end result may have nothing to do with the chrome because the pot metal part some times has bubbles that pop out when you go to strip and polish before plating and sometimes during plating. This is especially a problem with the thin fins on the upper grill. It is harder to find someone to do die cast (pot metal ) then regular steel (trim). Most plater don't do the die cast because of the typical problems that arise like I explained and the problems they have with customers because the part doesn't turn out well or the extra money it takes to make it look right (if that can even be done on some items) so it has been explained to me. The last set of uppers I had done cost close to 700.00 and I thought they could have been better. One type of separate repro panels are plastic and looks ok but the ones that come attached to the upper panels already are metal and look much better but the upper trim looks less then great . So you end up taking the upper panels off and re installing them into original upper panels.
Offline gimpystoy
« Reply #5 on: December 16, 2014, 07:44:06 PM »
TY
Now my delima begins plstic grills/ grills w panels move grills of grills w panels to OE panels! Concours can be frustrating.
Gimpy
« Reply #6 on: December 17, 2014, 03:08:50 AM »
TY
Gimpy
If money is a motivator the plastic ones are less expensive .If a more authentic look is more important then the more expensive metal grill/panel assembly makes more sense.
Offline gimpystoy
« Reply #7 on: December 17, 2014, 05:36:30 PM »
Bob: Money is becoming a big factor. I'm on the cusp of moving from Concours to nice driver level with this project. It sounds like the plastic is good for "nice Driver"
TY,
Gimpy
« Reply #8 on: December 17, 2014, 06:09:09 PM »
TY,
Gimpy
You wouldn't be the first one . Yes they are and the reason why I mentioned it.  ;)
Offline gimpystoy
Re: Interior upper quarter panel vent grills re chrome ?
« Reply #9 on: December 18, 2014, 07:39:10 PM »
Bob: Thanks so much fpr the advice and information. Looks like my post Christmas shopping and New Years project is setting up.
Merry Christmas and a healthy happy with smooth roads 015.
Gimpy
« Reply #10 on: May 18, 2021, 04:26:53 PM »
I took mine apart for plating since they look about 80% but I want better.
I used a Dremel and just broke through the swadged studs.
The question is what product are you guys using to glue these back on?
Pics?
