Author Topic: What is the best spray can Argent wheel paint ?  (Read 4288 times)
Offline zray
« on: December 03, 2014, 09:05:35 PM »
I know Eastwood sells it, so does Virginia Classic Mustang. Any opinins as to which is the better one color-wise ? Or is there a better one sold by someone else ?
Is there any consensus as to whether sandblasted  plain Ford 15" steel wheels need a primer first, or will the spray paint be all that's needed for  the best result ?
Z
« Last Edit: December 03, 2014, 09:07:55 PM by zray »
Looking for '65-'68 manual V-8 coupe
that doesn't need a new body
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
Re: What is the best spray can Argent wheel paint ?
« Reply #1 on: December 03, 2014, 09:37:00 PM »
I like Brant's.
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
Offline JKWilson
« Reply #2 on: December 03, 2014, 11:10:30 PM »
Z
I'll probably have a ton of people dress me down, but I recently did a set of plain steel 14" for my coupe and didn't prime after I had blasted them. Yes, I had gotten lazy and didn't feel like getting out the gun and mixing up some primer! :-[  Priming certainly doesn't hurt and mine will have hubcaps covering them also.
Here's how they came out (the tires were mounted a few days afterwards):
« Last Edit: December 03, 2014, 11:13:50 PM by JKWilson »
Offline zray
« Reply #3 on: December 04, 2014, 09:52:26 AM »
If I was going to have major hubcap, I'd be very tempted to forgo the primer as well. But since I'm shooting  for the look below, albeit  without the  exact period correct (expensive) wheels, I'd better  go  buy some primer .
Z
« Last Edit: December 04, 2014, 11:25:07 PM by zray »
Online rockhouse66
« Reply #4 on: December 04, 2014, 06:23:53 PM »
I had very good results with VHT Argent Wheel Paint, their SP188.
'66 GT FB
Offline JKWilson
« Reply #5 on: December 04, 2014, 06:31:36 PM »
If I was going to have major hubcap, I'd be very tempted to forgo the primer as well. But since I'm shooting the look below, albeit  without the  exact period correct (expensive) wheels, I'd better  go  buy some primer .
Z
I kinda figured that's what you were doing when you stated plain steel 15". That's also why I specified I went without primer on 14" AND with hubcaps. I'd have to agree with you 100% on priming first.
Offline GD64
  • Bronze Level Subscriber
« Reply #6 on: December 05, 2014, 10:14:19 AM »
Where they originally sprayed without the use of primer and/or did they receive some kind of electrochemical process prior to paint?
64 Galaxie (54A)
RHD Export Model
390 4V, Dual Range Automatic
Oaville, Ontario Assembly plant.
Offline Hipo giddyup
« Reply #7 on: December 05, 2014, 11:27:43 AM »
That's what I am thinking.. When I sandblasted the last set of standard 14" wheels,  I found nothing but the layer of black paint...? :o
Offline sportyworty
« Reply #8 on: December 05, 2014, 01:27:10 PM »
direct to metal
Offline TLea
« Reply #9 on: December 05, 2014, 05:58:37 PM »
I think best is Motorcraft brand. Same as its always been and still available from Ford
Offline zray
« Reply #10 on: December 05, 2014, 06:05:27 PM »
I took the Virginia Classic Mustang catalog listing for the MotorCraft spray paint to my local Ford dealer to see if they could order it.  After about  15 minutes they gave up, they couldn't find it anywhere on their computers.
Anybody got a current Ford Part number for it ?
Z.
« Reply #11 on: December 05, 2014, 07:08:33 PM »
What number did you use? The last one I have is D7AZ-19000-A.
