Author Topic: negative and positve battery cables  (Read 3594 times)
Offline macdude67
« on: April 06, 2010, 10:26:43 PM »
I am curious about the positive starter cable routing on a june 1964 mustang. The wiring schematics place it along the pass side shock tower then dropping down to the starter. On the MCA rules it mentions that the 64.5 negative cable must have the correct hold down. Does anyone have a pic of this? Where does the engine side of the negative cable mount and how does it mount to the block?
Re: negative and positve battery cables
« Reply #1 on: April 07, 2010, 01:05:35 AM »
Here's a pic of an original clamp that I restored a while back:
http://www.early-mustang.com/charles/Neg%20Battery%20Cable%20Clamp.JPG
This was only for generator-equipped V8 cars.
Offline macdude67
« Reply #2 on: April 07, 2010, 09:19:03 PM »
Can you take another picture of the area zoomed out a bit? So I can see where the attachment point is?
« Reply #3 on: April 08, 2010, 01:05:03 PM »
That edge is the battery tray.
The pic was taken probably 10+ years ago.  It is a car I helped a friend restore.
Offline kutzoh
  • Gold Level Subscriber
« Reply #4 on: April 08, 2010, 04:56:36 PM »
Charles-
    Is that clamp reproduced? I don't believe my coupe had one, at least not by the time I got it !
Greg
Offline macdude67
« Reply #5 on: April 08, 2010, 10:26:40 PM »
how about the routing for the starter cable?
« Reply #6 on: April 08, 2010, 10:52:02 PM »
Charles-
Greg
Yes, believe so.  They were listed on ebay.
« Reply #7 on: April 08, 2010, 11:05:33 PM »
Starter cable should route like any other V8, down the apron, couple wire clips, forking over to 1 or 2 clamps that come off the motor mount to block bolts and then attaching to the starter.  The assembly manual probably shows this.
« Reply #8 on: April 09, 2010, 11:31:08 PM »
If I remember correctly there were two ways to route the starter wire. There was a TSB article put out on the subject since they found a problem with the early routing and changed it
Will look to see if I have that TSB article and related drawings
« Last Edit: July 02, 2020, 06:17:09 PM by J_Speegle »
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #9 on: April 09, 2010, 11:35:40 PM »
I would just like to add on my June 29 64.5 the mounting hole for the clip is on the opposite area of the battery cut out area then the one pictured above. It is on the same side just closer to the shock tower then the front of the car.
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
