Author Topic: Shock Absorber bushing replacement  (Read 10799 times)
Re: Shock Absorber bushing replacement
« Reply #30 on: November 07, 2018, 11:25:34 AM »
Here's the OEM Autolite shock and all the parts. I pressed it back together using the hydraulic press, with the larger diameter socket supporting the shock while the smaller socket was used to press on the rubber bushing.
« Reply #31 on: November 07, 2018, 12:00:00 PM »
The results - not too good, but with a better bushing to start with the technique may work.
The Monroe bushing sheared off a little at the bottom, cut by the socket.
« Reply #32 on: November 07, 2018, 12:01:41 PM »
Also, it is just too narrow to ever look right. with the axle centered there is an appropriate amount of rubber on one side but not enough on the other.
« Reply #33 on: November 07, 2018, 12:02:50 PM »
Here is one of my NOS front shocks for comparison.
Offline 67350#1242
« Reply #34 on: November 07, 2018, 12:53:23 PM »
I have been successful swapping these out with either vintage or newer Gabriel bushings and crossbar.  As shown, the Monroe is too narrow and wrong profile.
Didn't need to use a press at all - just spray the donor bushing good with silicone spray,  put one end of the crossbar in a vise, then twist and pull it off.  The bushing and cross come out together.
Reverse process to install on the old shock - twist and push after soak with silicone.  Really easy peasy.
Kurt
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #35 on: November 07, 2018, 01:14:50 PM »
I agree that the real trick is first finding a acceptable bushing.
« Reply #36 on: November 07, 2018, 01:54:01 PM »
I ordered a set. More to follow. Thanks!
Kurt
Offline tobkob
« Reply #37 on: November 07, 2018, 09:57:04 PM »
Be sure to grease well before pressing the bushing in... ;)
TOB
« Reply #38 on: November 08, 2018, 12:52:29 PM »
Don't use a silicon based anything, easy in - easy out. In the past (for different slide in applications) liquid dish soap was "recommended".
Offline tobkob
« Reply #39 on: November 08, 2018, 02:48:47 PM »
Quote
+1... I just used grease from the grease gun so it would clean off...
TOB
« Reply #40 on: November 08, 2018, 03:35:22 PM »
Well the Gabriel shocks from Auto Zone arrived at my door about 1 hour ago.
Comparing the axle the Gabriel ones are probably the same material as the Monroe shocks. Thinner wall thickness compared to the original Autolite shocks. The shape was spot on compared to the originals though. Gabriel on the left, Autolite on the right.
« Reply #41 on: November 08, 2018, 03:38:51 PM »
I used WD40 as recommended. Within 10 minutes both shocks are done! I just need to finish stripping the old paint so they can be restored to original appearance.
One other observation, the Gabriel shocks have about 1" less travel than the Autolite shocks.
Thanks to all for the helpful suggestions!
« Reply #42 on: November 08, 2018, 07:06:38 PM »
i got bushings that work if needed
Offline 69GT350H
« Reply #43 on: November 08, 2018, 07:40:45 PM »
If someone has a pair of bushings for the 69 Autolite shocks, I'd like to replace the innertube rubber someone used on mine. Else if the Gabriel shocks are more reasonably priced and readily available, I'll go that route. What is the Gabriel shock part #?
« Reply #44 on: November 09, 2018, 09:10:10 AM »
The Gabriel part number is  82104 and they cost $19.99 each at Auto Zone.
