Author Topic: Shock Absorber bushing replacement  (Read 10795 times)
Offline tobkob
Re: Shock Absorber bushing replacement
« Reply #15 on: February 24, 2015, 10:48:43 AM »
If you just need the bushings you can go to Auto Zone and buy some Gabriel shocks. All my bushings were good except the top ones and if I remember correctly the lower ones may be a bit smaller.
TOB
« Reply #16 on: February 24, 2015, 06:08:45 PM »
If you just need the bushings you can go to Auto Zone and buy some Gabriel shocks. ............
Think you'll find those will not do - since they often have different markings or lack the factory ones :(
Offline petersixtfive
« Reply #17 on: February 24, 2015, 10:38:28 PM »
Top bushing with Harris markings
« Reply #18 on: September 21, 2018, 11:32:53 AM »
DSD Restorations web site seems to be gone. Does anyone know where to get these bushings now?
« Reply #19 on: September 21, 2018, 01:57:10 PM »
I'll pm you some contact info.
« Reply #20 on: September 21, 2018, 02:50:40 PM »
Thank you!
« Reply #21 on: September 21, 2018, 05:28:19 PM »
In judging we've seen allot of reproduction/replaced front shock upper bushings not holding up well. Not sure if its the rubber being used or owners/builders not using the upper A arm stops when the lift the cars off the suspension.  Just wanted to let others know this has become somewhat common unfortunately
« Reply #22 on: September 30, 2018, 09:28:23 AM »
DSD no longer offers them due to the longevity issue. I am going to rob a set from some NOS Motorcraft shocks.
« Reply #23 on: September 30, 2018, 04:08:08 PM »
The chances of those not holding up ether are less if you do not use the small brace under the upper control arm as mentioned in reply #21 and outlined in any of the 65-70 shop manuals (for good reason). I think Marcus made some up from the shop manual diagrams and sells them. FYI I painted mine florescent green to help me not forget to take them out before I let the car down.
« Reply #24 on: September 30, 2018, 04:13:23 PM »
Wouldn't that be after?
I use a block of wood, a "Home Depot" cutoff special.
« Reply #25 on: September 30, 2018, 05:24:51 PM »
Yes I should have clarified . Typically yes . I was thinking of my situation on a lift where I have a car on a 4 post lift I do the work with the car raised up in the air . I lift the suspension while on the 4 post lift so I am standing up while working . I let the body down but have forgotten to take the support out before lowering my four post lift and driving off.  It will fall out the first time you hit a good bump but that is not a good time.
« Reply #26 on: November 07, 2018, 11:04:01 AM »
The local Advance Auto Parts store sent me a 20% discount coupon which I used to buy a pair of Monroe shocks to try and rob the upper bushings from. Pressing out the bushing and axle together proved to be simple using my hydraulic press.
« Reply #27 on: November 07, 2018, 11:06:26 AM »
I also pressed the rotten upper bushing and axle from the Autolite assembly line original shocks. The ID of the assembly line shock is .950" while the Monroe shock is 1.125".
« Reply #28 on: November 07, 2018, 11:10:53 AM »
Here's the Monroe bushing, and a comparison of the axles.
The original axle (lower) is .625" OD made from 5/8" seamless .95" wall tubing. The Monroe axle (top, yellow) is made from rolled steel sheet .083" thick. So not only does it not look right, it isn't as strong.
« Last Edit: November 07, 2018, 11:22:07 AM by RoyceP »
« Reply #29 on: November 07, 2018, 11:17:39 AM »
Since the bushing had the proper ID, I set to work changing the OD. I slipped the axle over a 1/2" bolt chucked into my cordless drill. Initially I tried using the abrasive wheel, but soon moved over to the belt sander. This is tough rubber, it took quite a while to get the OD down to 1" which I thought would be an appropriate interference fit for the .95" hole in the shock.
Shown is the as removed bushing next to one that is fit to the OEM shock.
