Author Topic: Best way to restore disc rotors  (Read 5199 times)
Re: Best way to restore disc rotors
« Reply #15 on: November 29, 2014, 05:51:43 PM »
Also when you take it apart you can machine the top surface and sides of the hub like original too. There should be a contrast between the rotor hat and the hub. You can't do it properly when the studs are in the way.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #16 on: November 29, 2014, 06:34:46 PM »
Yep...agree with that Bob.  Those extra cuts would really make it look outstanding.
Marcus Anghel
www.anghelrestorations.com
Offline blackjadeboss
« Reply #17 on: November 29, 2014, 06:37:40 PM »
That's how I do it as well.
Nice!
« Reply #18 on: November 29, 2014, 08:05:10 PM »
It is a lot of extra work as you know Marcus and for those reading the machining on the hub needs to be protected or it will flash rust as will the edge of the rotor.
