Author Topic: Seat track mounting plates  (Read 8923 times)
Re: Seat track mounting plates
« Reply #30 on: May 10, 2013, 09:27:14 PM »
I have a contact at a local production plating company here locally.  I sent him an e-mail with the info you provided.  Will let you know if he can help.
Thanks for taking the initiative to try and figure this out!
Offline EJackson
« Reply #31 on: May 10, 2013, 09:34:43 PM »
Thank you for the compliment--sorry for the delay, I was hoping to have results sooner.
If you can ask your contact, I'm curious as to the carbon in the coatings. The materials engineer I worked with thought it was most likely contamination but it also might be an organic dye that imparts the color to the coating.
Ed.
1965 Convertible 5F08C600970
76A  P  29  16A  41  6  6
Prairie Bronze ext/Palomino int, black convertible top
« Reply #32 on: May 11, 2013, 03:33:27 PM »
Ed thanks for the effort. Now to figure out how to reproduce it ;)
Glad we were able to find at least an example with a strong original finish
Offline EJackson
« Reply #33 on: May 11, 2013, 05:55:20 PM »
Agreed. The EDAX was the easy part.  :D
PM sent.
Ed.
76A  P  29  16A  41  6  6
« Reply #34 on: March 30, 2020, 05:27:50 PM »
To add to this growing subject of study have the following to offer
Appears that at least San Jose used two different vendors for at least part of the year. This may help explain the variations of finishes or maybe not but the major purpose of the post is the two different styles/designs made and used.
At this point just posting for  considerations. Both examples are fairly close to one another
5R1473xxx - On this car a pair of each version was used. Not something that could be easy to see once installed
5R15089x - Looks like a makers mark stamped on the surface of the plate at about 7 o'clock. Notice you can see a stamp in the third (from the top) one in the picture above also though different loation
Also take note that we have versions posted with "flat" square ends and those that are pointed if we look at multiple plants.  Maybe we have a difference between 65 and 66 or a running change somewhere. Might be visible on an assembled car on the outer post
« Last Edit: March 30, 2020, 05:41:38 PM by J_Speegle »
