Author Topic: 67 GT shock question  (Read 1039 times)
Offline acman63
« on: November 21, 2014, 03:21:46 PM »
does anyone have original shocks on their 67 GT  that they can check whether they say made in USA  or made in Canada>   Pics would be great   email jim@shelbyparts.com    thanks
Re: 67 GT shock question
« Reply #1 on: November 21, 2014, 05:53:25 PM »
does anyone have original shocks on their 67 GT  that they can check whether they say made in USA  or made in Canada> ........
Believe the answer is normally it was based on where the car was assembled - different sub contractors (in the case Gabriel plants-  for different plants
San Jose would typically get MADE IN USA and Dearborn and NJ got the MADE IN CANADA. The type of tread and a couple of other construction details can vary between these two different supplying locations
« Reply #2 on: November 21, 2014, 06:23:15 PM »
Here are pics of rear shocks from my Dec SJ, GTA small block that I bought in 1980.  The style, coupled with date codes of November, and the other virgin aspects of the car, make these out to be original IMO.
I have the Jan 67 MPC and these part numbers (along with the rear spring part numbers and front spring colors) don't show up.  Can't figure that part out.
« Reply #3 on: November 21, 2014, 06:56:34 PM »
67gta289 - good example where the supply process was misdirected, a possible mistake made or some issue from the norm. Happened and its good that you can  document what your car came with - nice find. IF I may ask - fine or course threads?
Jim - as you well know shocks like batteries and exhaust are one of the most changed out items after all these years so original shocks are rare IMHO
Here are some examples - not all specific to the GT application. Hope they help in some way
C7ZF- CANADA bell shaped outer rear shock Believe this may be a service part from 1967 which may explain the difference in the outer tube design
C7ZF- USA front shock
C7ZF-B USA rear shock
« Reply #4 on: November 21, 2014, 08:19:06 PM »
Jeff,
The shocks are buried deep at the moment, but here are pics of the threads.  Appear to be fine thread.  I can get better detailed pictures with dimensions as well.
