Author Topic: 69 Coupe dual exhaust bracket factory part numbers  (Read 1589 times)
Offline 66RavenGTCoupe
« on: November 17, 2014, 11:30:27 PM »
Hi everyone,
I'm after the correct factory codes (not aftermarket codes) for the 69 dual exhaust upside-down "Y" hanger brackets that mount up under the seat. The ones with two metal brackets joined by a rubber strap. Need to buy a new set but must be NOS.
Thanks.
« Last Edit: November 18, 2014, 05:05:51 PM by 66RavenGTCoupe »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: 69 Coupe dual exhaust bracket factory part numbers
« Reply #1 on: November 17, 2014, 11:57:24 PM »
Hi everyone,
I'm after the correct factory codes (not aftermarket codes) for the 69 dual exhaust hanger brackets that mount up close to the tips. Need to buy a new set but must be NOS.
Thanks.
No engineering numbers on the brackets . check out Scott Fuller reproductions. http://www.scottfullerreproductions.com/1969_exhaust_options.html    He has picture comparisons next to originals.
« Reply #2 on: November 18, 2014, 01:20:27 AM »
Are these the ones your looking for?
http://www.scottfullerreproductions.com/catalog/item/4595229/10077180.htm
As Bob eluded to - you'll pay a premium for a paper sticker on a NOS part only to have to peal it off before you install the part and i will possibly be as rusty as a good used one :(
The three piece brackets (one for each side) are listed in an older MPC as
      Drivers -------------------Passenger
C5ZZ-5260-F-----------------C5ZZ-5260-F
C7ZZ-5277-A-----------------C7ZZ-5277-A
C8zz-or C7ZZ-5A231-B-------C7ZZ-5266-A
Bracket- insulator and J bracket
« Last Edit: November 18, 2014, 01:24:04 AM by J_Speegle »
« Reply #3 on: November 18, 2014, 05:06:53 PM »
No Sorry Jeff. I have improved on my description in the initial post.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #4 on: November 18, 2014, 08:23:42 PM »
The 69 didn't use a "Y" shaped muffler hanger - believe that was 70- 73 on dual exhaust. So not sure if you want the 70 - up part number or the 69 "other style" one (Shown below)
Right part - wrong finish
