Author Topic: Taking a closer look at '66 GT K-code  (Read 18880 times)
Offline 65,66,67UNRESTORED
Re: Taking a closer look at '66 GT K-code
« Reply #15 on: November 17, 2014, 06:53:03 PM »
No, but my Uncle did.
65 Fastback unrestored survivor Ivy Green, Black Interior, C code, 4speed, A/C
65 K Fastback unrestored survivor Ivy Green, Palomino Interior
65 Coupe unrestored Caspian Blue, White Vinyl Top, Blue Interior, K code
66 Convertible unrestored survivor Raven Black, Red Deluxe Interior, C code, A/C
« Reply #16 on: November 17, 2014, 07:12:19 PM »
Oct 20, 1975?  ;) Its a Motorcraft housing. Also the 65/66 would be all letters.
Yeah, you can see the "M" in the shadow, it's a replacement. I was distracted by New England picking on Indianapolis. And "all letters" except the year, as in 5KC.
« Reply #17 on: November 17, 2014, 07:20:06 PM »
Rims are all repops too, though I understand that is acceptable for Concours. In my opinion, allowing such things as "concours correct" take away from those who are showing restored/reburished originals. But I am sure opinions vary on such things.
Offline sgl66
« Reply #18 on: November 17, 2014, 09:10:30 PM »
Based on the level of workmanship skill seen elsewhere it should be relatively easy to determine if the radiator support had been replaced or not ;) .
You mean like this? ;)
Ignore anything that can be bolted on, original, NOS or repop. There are limited number of frame and sheetmetal details unique to a GT or dual exhaust car. 3 that I can see in detail are not correct.
Build sheet, invoice and welded sheetmetal dates could help change my mind that this is something more than a donor chassis with a mix of parts.
« Last Edit: November 17, 2014, 09:13:01 PM by sgibbs »
« Reply #19 on: November 17, 2014, 09:35:30 PM »
What manual transmission is installed? It is not a Toploader.
T10
Offline MyRed66GT
« Reply #20 on: November 17, 2014, 11:11:52 PM »
No kick panel carpet/trim.
Offline livetoride60
« Reply #21 on: November 18, 2014, 01:34:15 PM »
- The carb. is an above average C6ZF-C clone that was re-stamped. Some of the Hipo specific body features are even mimicked, both incorrectly. I don't want to write an FAQ for fraudsters so I'm leaving out the fine details.
Wow, nice try.
Offline drummingrocks
« Reply #22 on: November 18, 2014, 03:56:09 PM »
I hate those Styled Steel Wheels that have a gold tint to the painted inserts.  It looks awful.  I bought a set of these, not knowing about the "charcoal" inserts not being charcoal.  I opened the first box, then sent them back to the vendor.
Offline flyingfred
« Reply #23 on: November 18, 2014, 06:05:13 PM »
The engine fan is a repo.
With the transmission, fuel pump, engine fan and carburetor being high end items by themselves, this Kar is already overpriced if those items were the only issues.
-Fred-
Offline sgl66
« Reply #24 on: November 18, 2014, 09:52:36 PM »
Besides the choke cable, what else is that coming through firewall?
Offline flyingfred
« Reply #25 on: November 18, 2014, 10:22:27 PM »
I believe that the second thing that you are seeing is the wire loom to the heater motor and starter solenoid.
-Fred-
Offline sgl66
« Reply #26 on: November 18, 2014, 10:40:26 PM »
-Fred-
There is another black thing smaller than the choke cable. The wire loom would be the 3rd thing... ;)
Offline flyingfred
« Reply #27 on: November 19, 2014, 01:54:04 AM »
I may not have explained myself fully in my statement. I am not referring to the plug as my second thing. In looking at other pictures in the auction, I feel that the smaller thing that you are seeing is the wire loom to the heater motor and starter solenoid.
-Fred-
Offline zray
« Reply #28 on: November 19, 2014, 08:49:11 AM »
That's exactly why I sold the  SSW's that came with my car., ugh.
Z
Looking for '65-'68 manual V-8 coupe
that doesn't need a new body
« Reply #29 on: November 19, 2014, 08:58:19 AM »
I'm glad it's not just me, then!  That's one of those things that once you see it, you can't unsee it.  And those wheels are everywhere.  I see them all the time at shows.  Drives me crazy.
