Author Topic: lower steering shaft color  (Read 2494 times)
Offline kcodecoupe
« on: November 15, 2014, 10:08:02 PM »
what would be the correct color/finish for the firewall side of the lower steering column tube,steering shaft and brake line hold down self tapping screws, 70 metuchen car black standard int, thanks,
Re: lower steering shaft color
« Reply #1 on: November 15, 2014, 11:39:17 PM »
Inner or outer lower tube?
Believe the inner is semi-gloss black and the outer is dark charcoal metallic but pictures are so poorly lit in that area its difficult to double check in pictures
The lower shaft appear to be a darker natural bare steel with a natural section for attachment to the rag joint with the welding detail
Will check the screw but believe we will find the screw zinc plated - but will check
Offline kcodecoupe
« Reply #2 on: November 16, 2014, 07:22:20 AM »
Thank you for your reply jeff,   i was refering to any part of the steering column components and brake line fastners that are seen in the engine compartment side
« Reply #3 on: November 16, 2014, 07:05:18 PM »
Found some time to go through the examples - discovered that my mind was more focused on 69 details rather than 70 :( so here's some better help
Yes believe we are on the same page.
Looks like the outer tube was dark charcoal like the upper outer tube. The inner tube looks to have been  phosphate and oil or at least that look originally.  No weld detail on the lower inner steering shaft on the exterior- more of a press on. All bare steel other than bare steel and oil it appears.
Heads for the brake clamps appear to be phosphate and oil again.   But here are some pictures for you to look at
« Reply #4 on: November 16, 2014, 08:47:56 PM »
I saw a Carpenter repro of the rubber boot Saturday at a friends shop. It looked great.
Offline kcodecoupe
« Reply #5 on: November 17, 2014, 11:42:10 AM »
Jeff, thank you for information and posting the pictures it makes the lob go a lot smoother,  chuck.
« Reply #6 on: November 17, 2014, 09:07:00 PM »
Your welcome  Picture #2 is the best of them all as far as original finishes and condition. From one of Bob P's low mileage Dearborn 70 Boss 302's
Offline kcodecoupe
« Reply #7 on: November 29, 2014, 07:54:23 AM »
  Jeff i sent you a pm about a stamp, thanks.   chuck.
