Author Topic: '65-66 Vent Frame Weatherstrip--Correct Rivet?  (Read 3185 times)
Offline drummingrocks
« on: November 13, 2014, 10:41:37 AM »
Does anyone have a source for a correct rivet for the weatherstrip that rivets to the top of a '65-66 vent window frame?  The rivet that comes with the repros is just a standard rivet, whereas the original rivet had a larger head and fit the frame much better.
Here's the piece I'm referring to: https://www.npdlink.com/store/products/seal_vent_window_to_door_post-103803-0.html
Also, does a '67-68 use a similar setup?  I purchased new window runs for my '67 coupe, and it appears that they too are meant to rivet to the top of the window frame.
Re: '65-66 Vent Frame Weatherstrip--Correct Rivet?
« Reply #1 on: November 13, 2014, 11:54:15 AM »
I'm not aware of anyone making an exact rivet.  The originals look like they were chrome finish too.
67-8 uses a screw instead of a rivet, the top seal is made into the vertical run.
« Reply #2 on: November 13, 2014, 12:07:50 PM »
Charles, my main gripe with the last set of rivets I used was that they were more of a button head/standard rivet, whereas the original rivet had a flat head that perfectly filled the hole in the vent window frame.
Good to know that a '67 uses a screw instead of a rivet--that will save some headache!  Thanks!
« Reply #3 on: December 01, 2014, 11:48:22 AM »
This photo doesn't really show the heads of the rivets, but I wonder if the rivets in this Scott Drake kit are more correct?
Here's the link: http://www.cjponyparts.com/scott-drake-vent-window-rivet-tool-kit-1965-1966/p/HW1456/
« Reply #4 on: December 01, 2014, 06:06:18 PM »
Probably about the best you will find.  Only other option is having them custom made at Hanson Rivet, believe it's a 500 minimum.
« Reply #5 on: December 02, 2014, 10:29:56 AM »
Charles, is that tool/punch that's included in the kit the same thing I would need to install the glovebox door emblem we talked about in the other thread?
« Reply #6 on: December 02, 2014, 10:46:36 AM »
Hard to tell from the pic, it might flatten the rivet instead of spreading it.
« Reply #7 on: December 02, 2014, 04:08:05 PM »
My measurements for 64963-S as shown on Illustrated Section 230 page 5, 0.144D,0.250L,0.312D HD,0.035T HD,0.101ID 0.137L RECESS
From Granger, some options, see link for prices:
Steel, zinc plated, 1/4 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HBP8?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Aluminum, 1/4 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HCL7?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Stainless, 5/16 L, pk 50
http://www.grainger.com/product/Semi-Tubular-Rivet-1HEE3?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Steel, zinc plated, 5/16 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HBP9?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
I used the rivets in the kit but I needed to fabricate a die to stake and flare the bottom with my rivet tool.
« Reply #8 on: December 02, 2014, 04:20:03 PM »
Thanks, Jim.  Would the stainless or zinc plated steel be more correct?
« Reply #9 on: December 02, 2014, 04:42:18 PM »
The originals look chrome plated, so stainless would be your best bet.
Also, think I mentioned it before, that the originals are tapered from the top to fit the hole in the vent window frame.
« Reply #10 on: December 02, 2014, 04:46:23 PM »
You're right, I forgot about that.  The lack of taper might be what makes the reproduction fit so badly.
