Author Topic: Spare Tire Hold-Down Parts V8 late '65  (Read 1745 times)
CobraSpeed
  • Guest
« on: November 11, 2014, 05:01:53 PM »
« Last Edit: May 19, 2020, 06:02:22 PM by J_Speegle »
Offline ChrisV289
Re: Spare Tire Hold-Down Parts V8 late '65
« Reply #1 on: November 11, 2014, 07:27:58 PM »
I ordered the hold plate from NPD and for some reason all three prongs do not fit in the center of the steel wheel.  I can only get 2 out of the 3 to fit.  I don't know if that is correct or not or what the proper hold plate is...
2009 V6 Mustang Coupe
« Reply #2 on: November 11, 2014, 08:51:03 PM »
This is what I have on my San Jose built (Oct 65) 66 "K" car. All items came with the car, I refinished them.
I would think that Ford would not use a wing nut without some type of finish, cadmium or zinc plating. The wing nut is one of the first things you see when the trunk is opened and a natural finish would rust. That being said, there are three possibilities for the finish on factory installed wing nuts, cad/zinc, phosphate or none. We already know that NOS parts are "sometimes" different than original so when you get a "genuine" NOS anything, be leery (don't reject it, but be careful). We also know that after 50 (almost for a few) years a part will show its age. In a few instances it is called surface rust. You can get surface rust on a steel part from the moisture on your hand.
I think I'll err on the side of preservation and accept zinc plating.
Offline ChrisV289
« Reply #3 on: November 12, 2014, 07:04:13 PM »
Anyone have this same issue?
Offline Richard P.
« Reply #4 on: November 12, 2014, 09:21:24 PM »
Was the C5ZZ-1424-A for a steel spare wheel?
Was the C5ZZ-1424-B for a styled steel spare wheel? (NOS service replacement picture attached)
The top wing nut is correct. The bottom is what I've received as a reproduction. Notice the way the wing comes off of the nut on both units. Their is a good e-bay picture in the trunk section on this forum. I have five just like the e-bay posting. l
« Reply #5 on: November 12, 2014, 11:24:42 PM »
The pics above help, I see an obvious difference now.  Will keep an eye out for this from now on.
Offline Richard P.
« Reply #6 on: November 13, 2014, 06:00:02 AM »
Charles that's what I'm talking about. The way the wings come off.
Offline ChrisV289
« Reply #7 on: November 15, 2014, 04:58:12 PM »
So on an early 65 car, should there be prongs for the hold down for regular steel wheel?
