Author Topic: January 1965 San Jose build date - Correct Bolts  (Read 672 times)
Offline wm65
« on: November 07, 2014, 03:07:01 AM »
What are the correct markings on the inner fender bolts? Pics? Than you
Re: January 1965 San Jose build date - Correct Bolts
« Reply #1 on: November 07, 2014, 08:09:37 AM »
If you're talking about the bolts that hold the coil spring covers, those are usually 2 double-quote ticks, star washers.  As far as I know, these are not reproduced.  Hopefully Jeff will post a pic.
« Reply #2 on: November 07, 2014, 08:10:42 PM »
So basically around 5R170xxx-5R180xxx range
Here is the style/type Charles was referring to (Star washer with double hash)
Here is what I found most often for the fender bolts for that plant and time period  (star washer with "anchor" pattern)
« Last Edit: November 07, 2014, 08:15:32 PM by J_Speegle »
