Author Topic: Driver's Side Fresh Air Vent--Bent?  (Read 4171 times)
Offline drummingrocks
« on: November 03, 2014, 04:58:46 PM »
Over the past weekend, I had a chance to work on my '66 coupe.  It's a Metuchen car, built in December 1965.  The car has been in the family since my dad bought it with 11k miles in 1968, so I know what has and hasn't been done to the car.
Dad always complained that the driver's side fresh air vent under the dash would freeze you in the winter, even when it was completely closed.  Dad's older brother bought the car in the mid-70s, and also complained of the same thing; in fact, he finally stuffed rags up in the vent to seal it off.
Fast forward to last weekend.  I was up under the dash working on the pedal support, and I quickly found the problem: The fresh air vent was installed sideways at the factory!  Two of the three retainer nuts were installed, and the third one was left off since the vent being cocked sideways meant that the mounting stud didn't protrude far enough through the vent.  The vent assembly should pull up flush to the bottom of the cowl, but there was a good 1/4-inch gap between the bottom of the cowl and the fresh air vent. The vent was in effect always open.
After 45+ years of that vent freezing everyone during the winter, I finally went back and fixed it properly.  While I had it out, though, I noticed that the vent appears to be bent.  It almost looks as if one side has been knocked almost flat.  Could this have been done at the factory, or was it something that occurred after the fact?  I even thought that maybe the vent was made that way.
Re: Driver's Side Fresh Air Vent--Bent?
« Reply #1 on: November 03, 2014, 05:09:51 PM »
Assembly workers were trained to make things "fit". Any questions?
Offline JKWilson
« Reply #2 on: November 03, 2014, 09:54:22 PM »
I have the same style vent assembly in my Oct '65 Metuchen fastback. Most definitely not the way it's supposed to be!
« Reply #3 on: November 04, 2014, 12:06:17 AM »
Sure someone didn't kick it since it didn't work?  Lol!
« Reply #4 on: November 04, 2014, 10:34:51 AM »
That was actually my first guess!   ;D
« Reply #5 on: November 04, 2014, 11:10:46 AM »
It does look like it was possibly kicked or bent by someone's shoe.  Any of your family members that drove the car have big feet?  The paint cracking and missing paint indicates it was done after the piece was painted.
« Reply #6 on: November 04, 2014, 11:19:18 AM »
No, I'm 5'4 and my dad and his brother are both 5'6.  I did notice the paint cracking, and you're right--whatever happened occurred after the piece was painted.  Maybe the assembly line worker dropped the vent before putting it in the car.  If only these cars could talk...
Offline Brant
« Reply #7 on: November 04, 2014, 06:51:21 PM »
Most of them that I have observed are bent somewhat there...not sure why.
« Reply #8 on: November 05, 2014, 09:15:34 AM »
Thanks for the picture, Brant.  I'll leave mine as is--even if it's incorrect, it's so far up under the dash that it's virtually invisible.  Plus, I think of it like a battle scar--it's part of the car's history at this point.
« Reply #9 on: November 05, 2014, 05:41:44 PM »
.............  I'll leave mine as is--even if it's incorrect, it's so far up under the dash that it's virtually invisible.  ............
If the car is ever judged expect them to see it . IMHO real easy to see and every good judge is going to look under there since (at MCA) the area is "called out" in its own specific section.  Just a thought - as always your call though :)
« Last Edit: May 19, 2024, 01:44:30 PM by J_Speegle »
« Reply #10 on: November 06, 2014, 08:48:23 AM »
If the car is ever judges expect them to see it . IMHO real easy to see and every good judge is going to look under there since (at MCA) the area is "called out" in its own specific section.  Just a thought - as always your call though :)
Thanks, Jeff, but Dad got by for 45+ years with it being like that, so I will too!   It's part of the car's history.  ;D
« Reply #11 on: November 06, 2014, 02:50:13 PM »
So is the dent in the quarter panel of one of my cars - though its tied with the birth of one of my children don't thing I'll leave it - though its part of the car's history
We each get to make the choose then live by them ;)
OF course as mention your detail may just be a production detail yet documented
« Last Edit: November 06, 2014, 02:54:57 PM by J_Speegle »
