Author Topic: Floor Pan Change Over Period Discussion  (Read 3286 times)
CobraSpeed
  • Guest
« on: November 02, 2014, 12:46:05 AM »
« Last Edit: May 19, 2020, 06:03:44 PM by J_Speegle »
Offline drummingrocks
Re: Floor Pan Change Over Period Discussion
« Reply #1 on: November 02, 2014, 08:53:58 AM »
That generalization on emergency brake routing does not apply to late '65 Dearborn. Other assembly plants?
I figured it might have been phased out during the '65 model run.  I've never heard an approximation of when the later-style floor started being used.
« Reply #2 on: November 02, 2014, 02:11:15 PM »
I don't know if they have fixed this yet with the repro 1-piece floor, or if it's even on anyone's radar, but on a '65 the emergency brake cables went through a hump in the floor and over the rear framerail.  In '66, this switched to the cables just routing under the framerails.  A '65 floor will have those provisions, whereas a '66 floor will be flat there.
This area is poorly documented in both the Mustang Chassis Assembly drawings (or lack of) and the Ford Car Parts book.
My May 11, 65 San Jose has the 65 configuration. Others?
I think this part of the original thread need to be split off. Jeff?
« Reply #3 on: November 02, 2014, 04:59:55 PM »
Thought the site and members would benefit from splitting a discussion that developed in another thread related to when Ford changed from the floor pan design that allowed the rear E brake cables to pass between the rear frame rail and floor and the change to no passage way.
« Reply #4 on: November 02, 2014, 05:02:18 PM »
............I think this part of the original thread need to be split off. Jeff?
Done - One concern on my part and possibly others, is that details like this help people faking, cloning or choosing to take advantage of people be better at it.
Just a thought that always comes up when these things get discussed
Offline Brant
« Reply #5 on: November 03, 2014, 12:31:56 PM »
Concerning San Jose cars, the change seemed to occur in very late '65.  The first carryover '66 GT350s (actually '65 cars with mid June as the latest sheet metal dates) have the humps with a flat floor mixed in.  Just a very short time later, the flat floors only seem to show up on all of the cars.
So, at least in San Jose production, it would appear that the change over occurred in late '65.
I know that this has been discussed before, but on many of these late '65's (even with the hump), the rear parking brake cables are not routed over the frame rail.  They are attached to the floor pan with unique brackets.
« Reply #6 on: November 03, 2014, 01:16:00 PM »
Maybe mid May ?  My car has a owner's card dated May 29 and I don't know what a ' hump ' is .  The E brake cable has a bracket at the forward floor pan location and then to the rear ' unique brackets ' at the rear area below the GT exhaust hangers.  Then to the rear wheels below the frame rails.  No tunnels.  Where to locate a date stamp ?  Brian
Offline Brant
« Reply #7 on: November 03, 2014, 01:54:09 PM »
Here is a picture that I found of an earlier convertible showing the "humps" in the pans under the rear seat.
« Reply #8 on: November 03, 2014, 03:07:57 PM »
Well, maybe I do have humps ?   The ' unique brackets ' don't look so unique ' Look like brake line clips and hex heads to attach.  Brian
« Last Edit: November 03, 2014, 03:20:32 PM by Brian Conway »
« Reply #9 on: November 03, 2014, 04:59:54 PM »
I'm glad I stumbled across this thread.  I didn't realize the earlier thread had been split off--I thought someone had deleted my posts!
Offline Brant
« Reply #10 on: November 03, 2014, 06:06:25 PM »
Brian,
That all looks correct.  I called the brake cable clips "unique", because you do not find them on the majority of '65 cars.
Offline mts
« Reply #11 on: November 03, 2014, 07:08:56 PM »
my June 09, 1965 Dearborn has the 65 configuration........
« Reply #12 on: November 03, 2014, 08:05:19 PM »
Nah we wouldn't do that :)   The system does not post a redirect for splitting a topic like it does when we move one
If you did click on the "notify me of replies" then you'll be reminded that way
All is good
