Author Topic: Correct Plating For 1970+ Factory Hurst Shifter  (Read 2413 times)
Offline blackjadeboss
« on: November 02, 2014, 08:43:12 AM »
Does anyone definitively know the correct plating for a factory Hurst shifter?
Box and internal levers - Silver Cad?
Rods - Gold Cad?
Levers on trans - Phosphate and oil?
Trunions (connects rod to shifter lever) - Gold Cad?
Nuts on Trunions? - Phosphate and Oil
I believe this correct but want to be sure .....
Thanks in advance.
« Last Edit: November 02, 2014, 04:54:50 PM by J_Speegle »
Re: Correct Plating For 1970+ Factory Hurst Shifter
« Reply #1 on: November 04, 2014, 11:46:19 PM »
Will give it a try
Box and internal levers - Silver Cad? - Yes - looks like some are using clear or silver zinc due to availablility
Rods - Gold Cad? - Yes Except for the lock out rod - that one appears to be cad or dull zinc
Levers on trans - Phosphate and oil?  - Yes
Trunions (connects rod to shifter lever) - Gold Cad? -  Not sure
Nuts on Trunions? - Phosphate and Oil - Believe so
« Reply #2 on: November 06, 2014, 05:16:30 PM »
Thanks Jeff.
« Reply #3 on: November 11, 2014, 10:27:18 PM »
reverse rod gold 70 b2s & 351c BUT 70 b9 & cj reverse rod phos  since the tailshaft housing is unique doz cast # & reverse rod has different bends to it.
Offline rockhouse66
« Reply #4 on: November 12, 2014, 08:33:54 AM »
Sort of related, since it attaches to the shifter, but what about the reverse lockout rod that goes to the steering column?  What finish?
'66 GT FB
« Reply #5 on: November 12, 2014, 12:06:00 PM »
from what I seen silver on lockout rod & 70 b9 is unique (shorter since engine forward mount) without any ford # just a yellow color code but the others have ford eng# depending on which trans &engine 4-speed or auto.
Offline hopey
« Reply #6 on: January 29, 2023, 12:39:21 PM »
Could not find an answer using search, so resurrected this thread?
I am getting ready to restore/replate a 70 Ford Hurst shifter and was wondering if there had been a definitive answer to the plating on the trunions? I cannot tell from any of the originals I have, but have seen them yellow dichromate OR zinc /cad on various other restored cars.
Any help would be appreciated!
« Last Edit: January 29, 2023, 08:54:22 PM by hopey »
1970 BOSS 302
Built 11/15/69 Dearborn
Offline Anghelrestorations
    • Anghel Restorations
« Reply #7 on: February 01, 2023, 12:35:48 AM »
The trunions should be a zinc dichromate....adding a photo here.
20230131_211821 by Marcus Anghel, on Flickr
Marcus Anghel
www.anghelrestorations.com
Offline hopey
« Reply #8 on: February 01, 2023, 10:52:11 PM »
Thanks Marcus!
1970 BOSS 302
