are the mounting screws for the side scoops left natural or are they painted body color. car is grabber blue thanks
Does anyone know the ford part number for the side scoop front mounting screws and also the screws that mount the two small clips to the quarter panel that slip into the two slots at the rear of the side scoop.
Could someone possibly have or take a photo of the front mounting screw and scoop rear mounting clip mounting screw. I could possible match it up with something.
A question, who assembled side scoops on car, ford or a o smith. Would the 69/70 shelby "add/delete sheets" maybe tell me?
J_Speegle: Thanks.Could someone possibly have or take a photo of the front mounting screw and scoop rear mounting clip mounting screw. I could possible match it up with something. A question, who assembled side scoops on car, ford or a o smith. Would the 69/70 shelby "add/delete sheets" maybe tell me? Thanks for your help.
All of my AO Smith fiberglass parts have a part number, except the side scoops. Are they supposed to have a part number? The back if mine are rough, you can see the strands. They are thick, and I have no reason to believe they are not original. But as I was looking at mine vs other cars, the tale end of mine do not see to be as high as what I see in photos of others. I have tried to see if I can fit them higher up, but they do not fit the curves of the panel at all. Both my rear quarters are Dynacorn replacements, but I have photos that show the scoops shortly after I purchased the car in 1981 and they look to be in the same place.
Is this just an illusion due to the different angles?
