Author Topic: Sway Bar Bushings Installation  (Read 2316 times)
Offline Skyway65
  • Gold Level Subscriber
« on: April 03, 2010, 11:52:01 AM »
When replacing the stock front sway bar bushings how do you get them to slide onto the sway bar?  The new ones are pretty darn tight.  Will they stretch enough when heated, will dish soap help them to slide on?  The originals were not cut so I'm guessing there must be a trick to get the new ones on.
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Sway Bar Bushings Installation
« Reply #1 on: April 03, 2010, 11:46:10 PM »
Yes some can take some work especially if the weather is cold and you don't lube them up
Offline Skyway65
« Reply #2 on: April 04, 2010, 10:41:46 AM »
Thanks Jeff, it seems I'm learning something new everyday as I get this car put back  together. 8)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline rmaginnis
    • December 2010
« Reply #3 on: April 09, 2010, 02:45:36 AM »
I just cut them open with a utility knife.  I am almost certain the originals were 'overmolded' onto the bar by the supplier.
Rick
Rick Maginnis
April, '70 Dearborn Boss 302
0F02G18xxxx
