Author Topic: Smog pump rebuild and related questions  (Read 3219 times)
Offline Oz390
« on: April 02, 2010, 08:36:03 PM »
Have 2 OEM units (I think), appear to be '71 even thought they came with my 68's as casting numbers on covers are 116 and 170.  Both white fan.  Bought a new rebuilt unit and the casing and cover are a bit different, plus black fan.  Assuming the guts are the same and you can swap out the rotating assembly. Yes?
If so, how to remove and replace the fan? Steering wheel/PS pulley type remover/replacement tools (have both).  The rest seem pretty straightforward.
If not, does anyone sell a rebuild kit?  Bearing, vanes, or..????
Detail question, one has the "diffuser" type silencer.  Was this originally used on Mustangs ( early '68 390)?
Finally, have 2 different sized pulleys. C8AE-98480-A (4 3/4" dia) and -B (6" dia).  What are the application differences?
8R03S : 76A I 2A 15M 72 5 U
Re: Smog pump rebuild and related questions
« Reply #1 on: April 03, 2010, 02:18:09 AM »
The moving parts (vanes and such) I believe are interchangeable but to remove all of the guts you have to break a pin and I'm uncertain how you would repair that. Last one I did I removed all but the cage (center rotation section) and soaked it a couple of dates in Enviro-Rust (s?) stuff then reassembled it. Getting all the vans and wipers can take time and allot of patience ;)
The fans become brittle so I normally just break them. With heat and age they tend to bond themselves to the center hub.
As mentioned above I've left the front hub attached to the "cage" and just worked through the rear of the case
Not that I'm aware of (rebuild kits), white fans are about $70 ea
Nope - don't believe so
That's going to take some time to research
Offline Oz390
« Reply #2 on: April 03, 2010, 06:51:15 PM »
Thanks Jeff.  After getting the fan off (that sucker ws on tight, sheared a 3/8-18 bolts threads right off....) see two plastic nibs on the case, looks like the "pins" you are referring to.
On the fans the smaller appears to be for a '68 390 w/o AC and the larger a '68 289/302 w AC and/or PS per my one reference I found.... can anyone confirm?  Also think it should be 9C480, one unclear double stamp and one very faint....
« Reply #3 on: April 03, 2010, 08:42:43 PM »
The larger B pulley is the BB with A/C pulley. Bob
Online TLea
« Reply #4 on: April 03, 2010, 09:34:53 PM »
I assume what you are giving is the engineering # which is what is stamped on the pulley? The A has multiple apps but in the case of your BB it is a Thermactor non AC pulley. Th B is the BB AC pulley.
Offline Oz390
« Reply #5 on: April 08, 2010, 10:13:00 PM »
Tim, yep numbers stamped on the pulley's....
