Author Topic: 68 hood catch and latch bolts  (Read 3401 times)
« on: October 16, 2014, 10:51:16 PM »
Last weekend I judged 6 68 KR500s I noticed that the latch and catch were bolted with phosphate bolts. I have not see that on 68 Mustangs but can see no reason why they would be changed on the Shelby. Do any of you know?
Re: 68 hood catch and latch bolts
« Reply #1 on: October 17, 2014, 08:39:19 AM »
Have seen it quite a bit in the past and observed on original cars too.
Offline TLea
« Reply #2 on: October 17, 2014, 08:42:47 AM »
Yes, LOL
As Special Ed would say, "thats just the way it is" LOL
Its not necessarily a mustang/shelby thing as far as the striker. The bolt head markings match what we see for NJ production at time. Late NJ cars would have phosphate RBW bolts at striker, that fastener wasn't used at AO Smith. As far as hood latch obviously AO Smith attached those as they have the phosphate anchor bolts.
Best evidence of who did what is found at hood hinges where you see the RBW holding hinge to body and anchor holding hinge to hood.
I'm sure I can find some pictures if you give me a little time
note:since you said KRs is why I mentioned the RBWs. Early cars would have typically had anchors on striker/hood hinges
hope this helps
Offline TLea
« Reply #3 on: October 17, 2014, 08:48:08 AM »
Heres some pictures from magazines in 68 (courtesy of Mr Disher :D) Pretty obvious in pictures 1 & 4
http://www.thecoralsnake.com/ENGINE.HTML
Offline Laurie S.
  • Trouble
    • My 1968 Mustangs
« Reply #4 on: October 17, 2014, 01:25:08 PM »
My original coupe has the phosphate bolts.
Murphy, 1968 Coupe - Concours, Original Owner
Trouble, 1968 Fastback - Modified
MCA Gold Card Judge, 67-68 Concours
MCA Gold Card Judge, Modified - All Years
« Reply #5 on: October 17, 2014, 08:21:19 PM »
Have a number of pictures of Fuller's unrestored 68 NJ cars and they are the same - latch bolt finish is P& O while the latch support to radiator support are cad
Apparently just another variation between assembly plants :)
Offline Coralsnake
« Reply #6 on: October 17, 2014, 10:39:26 PM »
I believe the catch was pre-assembled to the support, since there is no need for adjustment.
A later operation installed the support. This would have been at Ford- NJ assembly. The bottom bolt on the support is also bright cad.
See also....(there are several more if you need them, I can supply larger versions)
Can we talk about brake booster check valves now?
 :D
« Last Edit: October 17, 2014, 10:44:42 PM by Coralsnake »
« Reply #7 on: October 17, 2014, 10:48:45 PM »
 :D
Invite you to start a new thread. Have you many found a difference between suppliers, plants or time period we should all be aware of?
Will look froward to a new thread soon  8)
« Reply #8 on: October 18, 2014, 12:22:00 AM »
Jeff would this pic be typical of a SJ catch?
« Reply #9 on: October 18, 2014, 12:49:54 AM »
All being the same finish matches what the couple of original SJ cars I pulled up0 quickly so I would say yes
« Reply #10 on: October 18, 2014, 08:56:38 AM »
What about a Dearborn car? Were they using the same suppler as NJ?
