Author Topic: 67 3 groove pulleys, need part numbers, source  (Read 992 times)
Offline 1965GTFB
« on: October 11, 2014, 05:53:57 PM »
Need part numbers for 3 groove pulleys for a 67 mustang with factory AC, and PS.  Only twist is car is a 67 but we are using a 65 289 block if that make a difference.  I have a 3 groove crank and 3 water pump but they interfere with each other.
So need is for:
-Pulley part numbers.
-Source for pulleys since one or both of mine may be incorrect.
Offline RocketScientist
Re: 67 3 groove pulleys, need part numbers, source
« Reply #1 on: October 12, 2014, 10:11:41 PM »
Try this site for starters:   http://mustangtek.com/index.html
I don't think that the 65 block should be different but you will be able to get an idea from here also.
