Author Topic: 64.5 SEAT BELTS  (Read 1639 times)
Offline kcodecoupe
64.5 SEAT BELTS
« on: October 06, 2014, 07:21:30 AM »
What color should the seat belts be for a 64.5 coupe with palomino int.
Offline DM_1964
Re: 64.5 SEAT BELTS
« Reply #1 on: October 06, 2014, 10:16:31 PM »
I've found the following pic in the gallery section after searching palomino, so I'd assume you're after a set of black belts with the spartan/alligator type buckle.
Regards,
Dom
Offline drummingrocks
Re: 64.5 SEAT BELTS
« Reply #2 on: October 07, 2014, 11:57:37 AM »
I can't speak of the transition from the earlier/alligator texture seatbelts to the later clamshell design, but this is what was in my '65:
I bought these belts from Charles Turner to replace generic aftermarkets that had been installed.  I know this doesn't really pertain to a 64 1/2 car, but this does at least show that there were Palomino-colored belts in 1965.
Offline NEFaurora
Re: 64.5 SEAT BELTS
« Reply #3 on: October 07, 2014, 06:08:13 PM »
I would think that March through June 1964 cars would ONLY have what is Pictured in Pic#1.  and July 1964 and after would have what is pictured in Picture#2, Though the car could also have the Metal "Deluxe" style belts as well as in Pic#1 since after 7-64 both were offered at the same time.  It depends on the early build date of the car.
The "Standard" Plastic Clamshell belts were not available before July 1964,  The earliest date stamping I have found for the Plastic Clamshell "Standard" belts is "7-64". The Metal "Deluxe" style belts were offered first, and the ONLY belts available until July 1964, Then both the "Standard" Plastic Clamshell and "Deluxe" Metal ones were available.  The "Standard" Plastic Clamshell belts were either ALL BLACK, or Color Coded to the Interior color, and the "Deluxe" Metal ones were either ALL Chrome Alligator skin Deluxe Buckles with Black or Color Coded belt material or Color coded Metal Deluxe Buckles with Buckles with Black or Color Coded belt material.
:o)
Tony K.
« Last Edit: October 07, 2014, 06:19:13 PM by NEFaurora »
MCA#70001
