Author Topic: Which Evapo-rust are you guys using?  (Read 3414 times)
priceless
  • Guest
« on: October 02, 2014, 01:08:29 PM »
I'm needing to use some evapo-rust for the first time. I read where you guys use it quite frequently.
A Buddy of mine says he's used the evapo-rust in the gray jug with exceptional results.  I have a water pump with new brass bearings installed. Will evapo-rust hurt the bearings?
My question is, which one is everybody using?
Below is from Ebay, was wondering if this is the one to use.
Thanks for any help.
http://www.ebay.com/itm/171411538666?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline rodster
Re: Which Evapo-rust are you guys using?
« Reply #1 on: October 02, 2014, 01:24:19 PM »
That's what I use and believe most folks do.  I found the best price for a gallon at my local Tractor Supply. $21.99/gal
From their website:
EVAPO-RUST is non-corrosive to steel and does not harm brass, copper, aluminum, gold, lead, titanium, steel, cast iron, chrome, solder points, vinyl, plastic, rubber, silicone, glass, cork, or wood.
More info:
http://www.evaporust.com/faq.html
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
priceless
  • Guest
« Reply #2 on: October 02, 2014, 04:15:23 PM »
Thanks very much for the info.
Rich
Offline 70 Cougar
« Reply #3 on: October 03, 2014, 04:51:49 AM »
National parts depot sells it.  The 32 ounce jug is quite small.  If you got other pieces you're planning to dip I would go for the full gallon.
https://www.nationalpartsdepot.com/store/?p=catalog&mode=newsearch&search_str=rust&parent=1&year=
If you combine the order with other parts for a total of over $300 then it qualifies for free shipping.  No special environmental shipping fees.
Great product imo.
Steve O
1970 Mercury Cougar
« Reply #4 on: October 03, 2014, 09:30:26 AM »
O'reilly auto parts has the 5 gallon with free shipping for around $90.
priceless
  • Guest
« Reply #5 on: October 03, 2014, 01:52:19 PM »
Thanks rodster, did find a gallon at TS for $21.99 and in stock.
Gallon is all I need. 8)
« Reply #6 on: October 03, 2014, 02:49:42 PM »
We'll see about that  ;)
Offline rodster
« Reply #7 on: October 03, 2014, 03:06:15 PM »
You're welcome.  Glad you had a TS nearby!
Yea, the stuff is habit forming.  ;)
I removed a very heavily rusted rear end cover from my SVO and was curious how well Evaporust would do on it. Well, about a gallon later.....(it was HEAVY rust!)  I got my results!
Not sure it was the best use of $22+ but my curiosity was satisfied.   ;D   I don't have a blast cabinet so that wasn't an option. Didn't find any cool factory markings tho'.  :(
1984 SVO - 2A
« Reply #8 on: October 03, 2014, 03:57:52 PM »
Yeah, that's what I think too! With longer parts like driveshafts and leaf springs to contend along with having a capped off  roofing gutter filled with the stuff only begs for having 5-10 gallons on hand...and even then, you will have to move things around to get eveything dunked ;)
Richard
« Reply #9 on: October 03, 2014, 10:15:09 PM »
Currently buy mine from Harbor Freight. Once the new shop is up and if I do allot will likely look into getting a barrel  ;)
priceless
  • Guest
« Reply #10 on: October 04, 2014, 04:29:45 PM »
Huh??, Just cleaning a little surface rust on a water pump.
« Reply #11 on: October 04, 2014, 07:25:33 PM »
I  think Charles was likely referring to the typical situation where you start out with one item then find another .... and another   that could use a little freshening up. Just like most of our restoration projected they seem to snow ball...... not that I've had allot of experience with snow nor the idea that someone would want to make balls from that stuff ;)
