Author Topic: Crank Bolt and Washer ?  (Read 1400 times)
« on: October 01, 2014, 07:45:58 PM »
This bolt and washer came off of a 66 San Jose 6 cyl. 200 c.i. motor long ago.  A recent discussion regarding crank washers got me curious.  This washer is 1 3/4" across, 3/16" thick, is concave on the bolt head side and has a beveled edge.  To me that is an unusual washer.  Was this a stock application ?   Thanks,  Brian
Offline wunderwerks
Re: Crank Bolt and Washer ?
« Reply #1 on: October 01, 2014, 11:23:36 PM »
Ford listed this washer part # C0DZ 6378-A as applying to all 170, 200 and 250s as 1.76" OD, .58" ID and .230" thick.
The bolt is listed as part # C1TE 6A340-B also applying to all six cyl. as a 9/16"-18 X 1 3/4" hex head.
The deflection you see in the washer was possibly caused by excessive resistance while using the bolt and washer to install the dampner pulley sometime in its past life.
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
« Reply #2 on: October 02, 2014, 02:13:03 PM »
Thank you WW for the research and post.  So it is the correct application for a 66 T code.  Washer seems to be extraordinarily thick, almost 1/4", and the guy that damaged the thing must have been a brute.  Brian
« Reply #3 on: October 03, 2014, 10:31:34 PM »
............ and the guy that damaged the thing must have been a brute.  Brian
Or had a impact turned up a bit  ::)
« Reply #4 on: October 07, 2014, 07:44:23 AM »
« Reply #5 on: October 07, 2014, 07:31:47 PM »
A pre-load crank washer ?    Brian
  http://forums.vintage-mustang.com/vintage-mustang-forum/807466-concaved-convexed-side.html
Unfortunately IMHO the original poster never says ( if Waynedid I missed it) the source of the washer. He mentioned that he  purchased it new..... but does nto say from where.... lots of questions before I assumed it was correct or like an  original. Got buckets of hardware and don't recall ever seeing  one from a early small block
Just me ;)
« Last Edit: October 07, 2014, 07:35:40 PM by J_Speegle »
