Author Topic: 70 boss 302 harmonic balalancer bolt & washer  (Read 1704 times)
Offline kcodecoupe
« on: September 27, 2014, 08:02:27 AM »
is a 70 boss 302 harmonic balancer crankshaft bolt and washer specific to a boss or same as a standard 302 or 289 hi po.
Re: 70 boss 302 harmonic balalancer bolt & washer
« Reply #1 on: September 27, 2014, 05:21:11 PM »
All I can report is that Ford serviced the bolt and washers. According to those books they serviced the bolt and washer with the same pieces as the regular 302 Washers for the 289 Hipo were serviced with a different thicker washer than the Boss 302, standard 289 and 302
Offline kcodecoupe
« Reply #2 on: September 27, 2014, 09:39:10 PM »
 Thanks Jeff, i removed my B2 balancer and the washer was concaved not looking very good so i am looking at using a thicker k code washer i have instead , i cant see where it would hurt,  chuck.
« Last Edit: September 27, 2014, 10:20:49 PM by J_Speegle »
« Reply #3 on: September 27, 2014, 10:20:30 PM »
Don't see a down side - the fraction of an inch less of threads engaging from the bolt to the balancer shouldn't be an issue
