Author Topic: AC Brush Mounting  (Read 979 times)
Offline ChrisV289
AC Brush Mounting
« on: September 18, 2014, 11:26:23 PM »
Just want to be sure I put this on correctly, the AC brush will be up against the compressor followed by a flat washer and then a bolt with a star washer on it.  Or will the flat washer be in between the AC brush and the compressor?  Also the bolts I took off have a flag in the middle while the ones I got from AMK have no head marking.  Are the ones I took off original as the brush was replaced since there is no engineering number or Fomoco stamp on top?
2009 V6 Mustang Coupe
Offline rocket289k
Re: AC Brush Mounting
« Reply #1 on: September 19, 2014, 01:19:14 AM »
Hi Chris,
I found a great picture of an AC system on a unrestored '65 Mustang that should answer all of your questions.
PS - An original set of brushes has the Ford part number stamped into it like in the picture I've attached.
Regards,
Ron
Offline ChrisV289
« Reply #2 on: September 19, 2014, 01:29:16 AM »
Hmm that one doesn't have the flat washers, just the star washers....
Offline rocket289k
« Reply #3 on: September 19, 2014, 02:10:59 AM »
I don't believe that I have flat washers either (just star washers).  I'll have to double check tomorrow.
Ron
« Reply #4 on: September 19, 2014, 05:18:01 PM »
Looked and found the use (very limited number of very close up pictures of this detail) of the flat washer on that mounting bolt on cars after 6R171xxx
A couple of close up picture. Agree that original brushes had engineering numbers visible on the top surface once part was mounted
