Author Topic: Yellow top coil restoration tip  (Read 19601 times)
Offline markb0729
  • South Jersey
Re: Yellow top coil restoration tip
« Reply #45 on: December 03, 2017, 01:57:42 AM »
Thanks for the update Bill.  I'm going to place an order.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline preaction
« Reply #46 on: December 03, 2017, 04:58:16 PM »
Mark, I have a few cans left over from a case purchase if your interested cost plus shipping.
« Reply #47 on: December 08, 2017, 10:36:16 PM »
A few questions, as I just received my Rustoleum paint today.
My current 2D stock coil needs a refresh and a better date code.
Are we still going with this date format (using "0LEC" as the decal's date code, for example)?
0=year
L=November
E=5th week
C=shift
Since most of my engine is end Dec 66/Jan 67
is there a batch of coils made that fits this date?
I was thinking of "7AAC".
Is the coil stamp supposed to be really well done or like someone didn't care much and just stamped it a bit sloppy?
My current coil is certainly not done in a straight line (a very gradual "S" curve on the box outline.
« Reply #48 on: December 09, 2017, 12:12:09 AM »
0=year
L=November
E=5th week
C=shift
When was your engine assembled?  That is the most important guiding date.  Right now I would choose a December date
« Reply #49 on: December 09, 2017, 12:32:48 AM »
Or better yet November IMO.
« Reply #50 on: December 09, 2017, 12:35:22 AM »
FYI the date debate is pretty much mute since once properly indexed in the coil bracket as factory the date code is covered.
« Reply #51 on: December 09, 2017, 12:43:07 AM »
Is that because a large batch was run then?
The casting date of most engine pieces was in Dec/Jan. I don't recall the block assembly date and the block is hard to get at presently. I'm thinking early January.
« Reply #52 on: December 09, 2017, 12:58:49 AM »
No I don't believe they were made in big batches but instead were being produced consistently since they were used on millions of Ford products as well as supplying the aftermarket and over the counter needs of the company. I would just choose a wider gap if it were my car for an engine built in Jan
« Reply #53 on: December 09, 2017, 01:17:32 AM »
Ok, got it. Thanks for your insight.
I'll whip up a vinyl paint mask and paint the silver.
Offline 69GT350H
« Reply #54 on: December 09, 2017, 01:36:05 AM »
Menards carries this item at some of their stores. Handy if you are in the North Central US.
Otherwise, this is how shipping works (for me):
Merchandise Subtotal: $3.68
Processing Fees:         $2.80
Shipping Charges:      $6.71
Pretax Subtotal:       $13.19
So for 1/2 the cost of a case from HD you get 1 can. Yea, I hate to have so much waste as well. Actually, I just did a search and do not see the case available from HD anymore.
« Reply #55 on: January 27, 2018, 06:39:10 PM »
Finally back to the shop . . .
I've seen a number of yellow coils, but the correct black case to yellow plastic transition (paint) line is not clear to me.
On the left in this pic is a repop which I think has the correct line demarcation. None of the yellow 'plastic' portion is painted.
On the right is an original coil, but the plastic or yellow portion of the coil has been painted above the metal band by a restorer.
Is either paint scheme correct, from a concours perspective?
As an aside the original coil says "Dist." with the period included. As does "BAT."
The repop say "DISI" and "BAT" with no period. Odd that such an easy mistake to spot made it through into production.
« Reply #56 on: January 27, 2018, 06:53:49 PM »
Have seen the vast majority of original coils with black over the yellow plastic end To me it always suggested a mask of sorts not often a sharp paint edge. You can find paint "blow outs" around the BAT and DIS post stands but not always
« Reply #57 on: January 27, 2018, 07:18:50 PM »
+1 to the previous restorer !
« Reply #58 on: January 27, 2018, 08:08:29 PM »
+++ 1
« Reply #59 on: January 27, 2018, 08:45:27 PM »
The repro coils say "disi" instead of "dist"?  Doesn't anyone know English overseas?
