Author Topic: looking for complete wire loom for 1967 Mustang Fastback GTA S code  (Read 1686 times)
Offline travnemi
  • Travis Waters
I looking to buy a complete wire loom set for a 1967 Mustang Fastback GTA S code. Would anyone know who carries a good concourse quality set?
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
Re: looking for complete wire loom for 1967 Mustang Fastback GTA S code
« Reply #1 on: September 06, 2014, 02:38:41 PM »
I would restore the under dash portion. There is usually not much wrong with them.
Marty
« Reply #2 on: September 06, 2014, 03:27:30 PM »
Marty
I would try to restore all but with that said the taillight harness and headlight harness are the typical candidates for repro replacement. The headlight harness unless substantially cut and spliced is relatively easy to restore. The taillight harness with the weave covering not so much.
« Reply #3 on: September 06, 2014, 05:38:26 PM »
Marty
+1 Besides, on just the dash harness, there are a few running changes and I believe a bit of changes between original suppliers across the span of production,  and not just the "with tach" or "without tach" options. Headlamp harnesses (if I have this correct) are also "with tach" or "without" Then add the "with Fog" and "without fog" and mix it with the "with tach", "no Fog" and so on. Alternator harnesses are 6 cylinder, Big Block or Small Block and the with tach and w/o tach also applies. Engine feed is the same "with or without tach" (though I cannot recall seeing a 6cylinder with tach option) for the 3 basic engine blocks.
Tailamp harnesses had a few options too, "With Low Fuel" and "without", and I believe convertible was different than Coupe/Fastback. So a few variations available there too.
Headlamp and engine harnesses take a lot of heat over the years and the plastic insulation gets stiff and begins to break down. The weave covering is often ratty looking on the tailamp harnesses and then the taillight sockets look rather poor for aging (or rust).
Alloy Metals is said to be the best repro available at this time. NPD and Virginia Classic, as well as many other good Mustang retailers sell them. Mr. Mustang is a cheaper version, but not much cheaper and said to not have as good of quality. It has been said in various discussions I have read that Scott Drake uses the Mr. Mustang version of the reproductions.
I have read info for a few years at different sites, mostly for my door harnesses and the tailamp harness, so this information is based upon the efforts of my searching.
I am in the middle of restoring mine and I was surprised my headlamp and alternator harnesses are rather nice considering they spent the first 30 years in HOT dessert areas of So.Ca. I will be probably sending them out to Randy here on the forum (username Midlife) to go over and repair/clean them up. Nothing more frustrating than "electrical problems" on a fresh restore, and nothing stands out as ugly as old wiring flapping around the engine compartment and trunk.
Richard
« Reply #4 on: September 06, 2014, 10:58:36 PM »
+1.  If you're looking for concours-level restorations, Pat White may still be doing that.  Having refurbished 350+ harnesses, the amount of work to restore harnesses to concours level is astonishingly high, so be prepared to pay a pretty penny or spend several hours doing it yourself.  The underdash harness is the one harness that is not seen unless one contorts one's body to do so, so that is the one harness where concours-level effort doesn't make sense, but a refurbishment to restore functionality is relatively inexpensive.
My normal advice is to refurbish the underdash components, but to buy reproductions for the engine and tail-lights if one wants them to look well.  Despite the heat and age, the headlight harnesses tend to be refurbishable to a high level of respectability (not quite concours correct or perfect), but rarely do the engine gauge feed harnesses survive.  Tail-light harnesses rarely have intact fabric looms, and the bulb sockets easily corrode, but can be refurbished for functionality.  I do refurbish a fair amount of headlight and tail-light harnesses, but rarely for the concours crowd.
I hope this information is of some help to the original poster and others.
