Author Topic: 65 Wiper Switch ?  (Read 2872 times)
65 Wiper Switch ?
« on: September 05, 2014, 11:07:47 PM »
     Was a one speed windshield wiper with washer available for the 1965 Mustang ?  Thanks,  Brian
« Last Edit: September 06, 2014, 10:15:10 PM by Brian Conway »
Re: 65 Wiper ?
« Reply #1 on: September 06, 2014, 08:04:20 AM »
Yes.
Re: 65 Wiper ?
« Reply #2 on: September 06, 2014, 10:32:54 AM »
Thanks for the reply and confirmation.  Another couple of questions please ?   1.  I have a C4ZB-17A553-C1, 7 pin, one click switch which seems to have some ' washer pull ' .  The harness uses 5 pins, the washer pump another then there is a white wire spade connector without a home ?   2.  The harness wiper motor connection is a three hole plug with a separate black spade connector.  Is the 65 wiper motor the same three prong connector for wiper/washer and wiper non washer ?  Thanks,  Brian
« Last Edit: September 06, 2014, 10:35:39 AM by Brian Conway »
Re: 65 Wiper Switch ?
« Reply #3 on: September 06, 2014, 10:44:02 PM »
That's a one-speed wiper.  The two unused spade lugs on the wiper switch itself are for the washer pump: one lead is power and the other lead goes out to the washer pump (the position of each wire is not important as it is a simple switch).  The washer pump is independent of the wiper itself.   The two speed wipers have more spades, as does the connector.  At the wiper motor, there is a four pin plug along with two spade leads (green wires with 90* spade connectors).  I believe the washer is still independent of the wiper motor in the two speed variant.
Offline rocket289k
« Reply #4 on: September 06, 2014, 11:18:47 PM »
+1 that's my understanding as well.
Regards,
Ron
« Reply #5 on: September 07, 2014, 12:40:43 PM »
Thanks for the additional information.  Picture is of the fuse block.  At the top/right is the washer pump power lead to the wiper switch ?  Just trying to get as much info as I can before getting in there.  As you guys know tight quarters and 48 year old everything.   Brian
« Last Edit: September 07, 2014, 01:15:04 PM by Brian Conway »
« Reply #6 on: September 07, 2014, 02:13:46 PM »
http://www.concoursmustang.com/forum/index.php?topic=8264.msg47830#msg47830     It would appear most everything I need to know is here.    Thanks, Brian
« Last Edit: September 07, 2014, 02:16:43 PM by Brian Conway »
« Reply #7 on: September 07, 2014, 08:32:14 PM »
Power lead is typically picked up at the ACC post on the back of the ignition switch, although there is a white wire with a female bullet plug that is fused via the top horizontal fuse (ACC) that is part of the late 1966 harness design (which is what you have).
I do not see what you are referring to in the picture.
« Reply #8 on: September 07, 2014, 09:41:12 PM »
Thanks for the interest.  The owners manual fuse box diagram has a provision for a 14  amp fuse for a single speed windshield washer pump and to the left of that is, on my car, the power lead for the washer pump.   I don't think this is a late 66 set up.  I have not gotten in there yet but I am pretty sure of what I will find.  I think the hardest part will be unplugging the harness from the switch.  Brian
« Last Edit: September 07, 2014, 10:38:29 PM by Brian Conway »
