Author Topic: 68.5 Grill Color ?  (Read 7846 times)
Offline toohey
68.5 Grill Color ?
« on: March 28, 2010, 07:42:06 AM »
Hi Guys,
Can anyone tell me what paint colors were used on the grill of the 68.5 Mustang and the areas to which it was applied (Dearborn, May Build)?
Thanks Again
Matt
Dearborn 68.5 CJ
Offline DTruitt
Re: 68.5 Grill Color ?
« Reply #1 on: April 03, 2010, 10:33:45 PM »
Outside the large corral and inside the small corral is black.  Inside the large corral it is a light metallic blue (similar to the 65 grill paint, but not exactly).  I am sure others will chime in.
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
Offline toohey
« Reply #2 on: April 04, 2010, 07:24:07 PM »
Thanks Danny.  NPD have listed a Charcoal Blue paint for the 67 and 65 grilles, has anyone used these? Would the paint for the 67 be a closer match?
Matt
Dearborn 68.5 CJ
Offline Oz390
« Reply #3 on: April 06, 2010, 05:51:31 AM »
If it is the same charcoal blue I bought a while back it is far too light for the '68 grille.  It is almost a sky blue, and the grille is quite dark.  I have a NOS service replacement '68 grille (dated early 70's, '70 or '71 IIRC) and the color of the NPD grille paint was nowhere near correct when I compared the two....
8R03S : 76A I 2A 15M 72 5 U
Offline toohey
« Reply #4 on: April 06, 2010, 06:50:04 PM »
Thanks Oz,  I've purchased a can of paint for the 65 grille, the shop called it gunmetal blue.  I'll see how it looks and make a decision whether or not to use it.
Matt
Dearborn 68.5 CJ
« Reply #5 on: April 06, 2010, 08:16:21 PM »
Matt
Good idea IMHO - since some of the rattle cans can be way off
But of course (to help others) let us know what you find
Offline toohey
« Reply #6 on: May 10, 2010, 04:46:04 AM »
Well I've finally got back to the grille.  I'm as happy as I can be with the color, it's quite dark and doesn't jump out.
What do you think?
Matt
Dearborn 68.5 CJ
Offline Sunlitgold68
« Reply #7 on: May 10, 2010, 09:39:35 AM »
Is this blue colored section correct for all 1968 grills?
8T01C204XXX
Built May 14th, 1968
« Reply #8 on: May 10, 2010, 12:52:53 PM »
No, just GT's.
Offline Oz390
« Reply #9 on: May 15, 2010, 11:33:14 AM »
Quote
No, just GT's
Never seen reference to a painting difference on grilles for GT vs. non GT before...
« Reply #10 on: May 15, 2010, 01:43:16 PM »
Are you saying fog lights were a regular production option for all Mustangs in '68?
Offline Oz390
« Reply #11 on: May 17, 2010, 03:53:11 PM »
No, I know fogs were GT or add on and not standard.
I have a '68 Ford service replacement non-GT grille and it has the black/blue two tone, which you indicate is GT only, yet it  has no fog cutouts...
Am wondering if it was a one-size-fits-all replacement that is "incorrect" for a non GT car. (its a 70 or 71 mfg date IIRC) And if so, why Ford would go to the expense of painting two tone if it was only correct for GT's... which were a smaller percentage of cars than non-GT...  would not seem logical to me to make a service replacement for the smaller production configuration.
« Last Edit: May 17, 2010, 03:55:04 PM by Oz390 »
« Reply #12 on: May 17, 2010, 04:15:26 PM »
Seeing as this is a service replacement grille you are using as an example, I don't think it is a good reference as we know there can be many varieties and quality levels of service parts.  I would just chalk up the service part as an odd-ball and cut out the holes for fog lights if you need to use it for that.
Offline Oz390
« Reply #13 on: May 17, 2010, 04:26:50 PM »
I have a non GT '68 I bought it for, guess I'll stash it and use a restored OEM painted SGB, as it appears a non GT would get dinged as incorrect for blue on black...
Thanks...
« Reply #14 on: May 17, 2010, 07:54:26 PM »
might be getting too technical but I discovered satin black was actually a closer match than semi gloss for the 68 grill. I guess either one would work though.
8T01C204XXX
