Author Topic: 1967 14" Styled Steel Wheels  (Read 10123 times)
Offline travnemi
  • Travis Waters
« on: September 02, 2014, 08:56:20 PM »
I have a 1967 Mustang Fastback 390 GTA, the Marti Report says it came with 14" Styled Steel Wheels. When I went to purchase them, there were many styles of them. Any help would help. Many options to choose from Like 5.5", 6" wide wheels, Black rims with chrome centers and beauty rings, like in the attached photo. http://www.cjponyparts.com/scott-drake-wheel-14-inch-x-5-5-inch-styled-steel-1967/p/W526-V/
Thanks in advance,
Travis Waters
« Last Edit: September 02, 2014, 09:23:13 PM by travnemi »
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
Re: 1967 14" Styled Steel Wheels
« Reply #1 on: September 02, 2014, 09:45:16 PM »
For 1967 I believe that they should be 14 x 5-1/2 wide with beauty rings. The MPC calls out 'painted grey'.
Offline travnemi
  • Travis Waters
« Reply #2 on: September 02, 2014, 09:51:20 PM »
I wasn't sure if the rim is supposed to be black with chrome center and black inserts like the photo or if the rim was all chrome with black inserts. Here's what I have to choose from,
Travis Waters
Mine -
« Reply #3 on: September 02, 2014, 09:59:43 PM »
14x5.5, rim painted black, centers around stud holes a charcoal gray. Trim rings (I believe polished and not brushed for 67 but not 100% sure on that detail).  The lower one looks more correct, but can't tell if the centers are black or gray.  Originals of course are riveted not welded ;)
Offline travnemi
  • Travis Waters
« Reply #4 on: September 03, 2014, 10:14:26 PM »
The centers are supposed to have charcoal gray and not the bronze?
Travis Waters
Mine -
Offline travnemi
  • Travis Waters
« Reply #5 on: September 03, 2014, 10:21:53 PM »
I have another question. The color of the center caps
Travis Waters
Mine -
Offline denonito
« Reply #6 on: September 03, 2014, 11:33:05 PM »
To  67gta289
    Even though it is a Cougar shop, WCCC(West Coast Classic Cougar) has a lot of info about Mustangs on their website. They show that 1968 is the only year that both Cougar and Mustangs had trim rings with the brushed look(http://www2.cougarpartscatalog.com/c8zz-1210-b.html) on the trim rings, so 67 would be chrome. I actually have 68 Cougar styled steel on my '67 coupe with 68 trim rings and red mustang centers, painted "dark argent" instead of the light argent that is correct for the Cougar. It doesn't look bad to most people, but then they don't know it's not correct.
7R01A San Jose built, UEK1xx CA Black/Yellow
« Reply #7 on: September 04, 2014, 02:30:22 AM »
Blue and the chrome base is designed with a somewhat scalloped/spoke design
To  67gta289
    Even though it is a Cougar shop, WCCC(West Coast Classic Cougar) has a lot of info about Mustangs on their website. They show that 1968 is the only year that both Cougar and Mustangs .......
Don't know about all years of Cougars  - Ford describes 70 and 71 at least as brushed also but all this talk is getting off thread a bit ;)
Offline Hipo giddyup
« Reply #8 on: September 04, 2014, 01:03:00 PM »
   +1  Here's my 67 coupe with styled steels. 14x5.5, black rim, charcoal gray painted center, blue center caps. Been years since i did this same research but seems to be still correct to this day.  ;)
Offline travnemi
  • Travis Waters
« Reply #9 on: September 04, 2014, 10:45:51 PM »
SWEET THANKS!!! I was pulling my hair out, trying to figure out which ones to get.
Travis Waters
Mine -
« Reply #10 on: January 02, 2015, 01:48:18 PM »
I'm cleaning up & repainting my OE styled steel wheels (has the rivets).
Anybody with a good recommendation for the CHARCOAL color?
ALSO: It looks like the outer BLACK portion of the wheels may have been dipped rather than sprayed. Any good ideas how to try and duplicate these two different finishes, a durable "do-able" process that will last? I will have all the paint removed after the EvapoRust eats away the rust. Since there was some minor pitting inside the wheel, Boeshield should work to help keep rust from returning I think..but I was looking for a process order after all the rust and paint is gone. Something on the order of:
1.) Clean Wheels and soak in Evaporust till all rust is gone.
2.) Aviation Stripper on any remaining paint.
3.) (next step?)
4.) (next step?)
5.) (next/final step?)
6.) Mount & Balance Tires
I have 3rd wheel soaking in Evaporust, first two already de-rusted, I am stripping the paint now.
« Last Edit: January 02, 2015, 02:19:49 PM by 67gtasanjose »
« Reply #11 on: January 02, 2015, 05:49:36 PM »
If the chrome is OK, then lightly sand and paint the backs and rim part of the front semi-gloss black. Then mask and paint the charcoal. If the chrome is not OK, think new.
Offline mtinkham
  • That'll be easy
« Reply #12 on: July 14, 2023, 08:37:34 PM »
I know this is a very old thread. Wondering what paint is recommended for the argent portion of the wheels. These would be for my signature car, if plant and time-frame make a difference.
Mark
Offline mtinkham
  • That'll be easy
« Reply #13 on: July 20, 2023, 01:50:05 PM »
So simply charcoal paint would be applicable?
« Reply #14 on: July 20, 2023, 02:41:10 PM »
I think it was called dark argent.
