Author Topic: 1966 Harmonic Balancer Finish  (Read 1089 times)
Offline Building 3
« on: August 29, 2014, 01:16:25 PM »
First week of December 1965 engine build:  The rules state:  "Harmonic Balancer may be block color, black, or natural."  However, is there a more acceptable answer?  Do you find that more are black, or engine color, or natural? Which would be the best way to go on this one for a December, week 1, 1965 engine build?  Thanks!
Re: 1966 Harmonic Balancer Finish
« Reply #1 on: August 29, 2014, 03:24:09 PM »
Black is by far the most typical we see, but have seen a lot of natural ones too.  Unless you have convincing proof that yours was natural or other cars built around the same time, I would lean towards black.  Mainly because it's easier to maintain.
Offline Building 3
« Reply #2 on: August 29, 2014, 04:04:44 PM »
Thank you.  That is what I will do.
« Reply #3 on: August 30, 2014, 12:41:41 AM »
Semi-gloss black faded to bare around the center front where the pulley and mounting bolt attaches if you look at the factory pictures and even service replacements IMHO. Some factory pictures look as if the face (mounting face for the pulley ) was machined bare after painting
All semi-gloss will likely work if you go that route - hard to see the center ones the pulleys and the engine is installed in the car
« Last Edit: August 31, 2014, 04:48:51 PM by J_Speegle »
Offline Building 3
« Reply #4 on: August 31, 2014, 03:47:09 PM »
Thanks for the insight on the proper paint application.
