I've been driving my '67 coupe daily over the past few weeks, and it's recently developed a new problem (in addition to all the problems it already had). Over the last week or so, the amp gauge needle has stopped staying in the middle of the gauge and has started staying on the above normal "charge" side. It's very noticeable when the car is first started, and then it slowly eases back down into the normal/middle area as the car warms up. However, more recently, it's stopped even doing that and the needle almost always stays on the overcharging side of the gauge.
I suspected either the voltage regulator (clearly not the original, but a parts store replacement) or the alternator. I pulled a known good VR off of my '65 convertible, but there was no change. I put a mechanical gauge on the battery, and it was receiving around 14 volts. Every now and then, it would charge above 14 volts, but not excessively. Finally, I swapped a known good alternator off of another car, and still, no change.
At this point, am I correct in thinking it has to be in the gauge or wiring? I really don't think the charging system is charging as hard as the gauge indicates, otherwise the battery would boil over. I thought maybe the instrument voltage regulator on the back of the dash had gone out, but if it had, wouldn't it make all of the gauges read incorrectly? The fuel and temp gauges are reading fine and don't fluctuate while the car's running.
Any ideas, or suggestions on where to go from here? Prior to this problem developing, the amp gauge needle always stayed perfectly in the middle.
