Author Topic: 69 brake caliper finish  (Read 1924 times)
Offline 69eliminator
« on: August 26, 2014, 12:14:46 AM »
I am trying to determine the correct finish for my 69 Eliminators front calipers.
Thanks for any comments
Best
Brian
1969 Cougar Eliminator 428 CJ Q Code with AC , PS, PDB, C6 Transmission,Traction-Lok Diff. 3.00. Bright yellow paint.
Dearborn 6/69
Re: 69 brake caliper finish
« Reply #1 on: August 26, 2014, 01:04:06 AM »
Before someone else asks - what wheels did you car originally come with?
Sorry for the technical problems with the first request :(
« Reply #2 on: August 26, 2014, 01:20:48 AM »
there is a method to his madness  ;D
« Reply #3 on: August 26, 2014, 08:31:48 AM »
GT  wheel with trim ring without the gt logo on center cap. 14" wheel
« Last Edit: August 26, 2014, 08:36:48 AM by 69eliminator »
Dearborn 6/69
« Reply #4 on: August 26, 2014, 12:53:48 PM »
On some of the open spoke design wheels (69/70 Shelby) the front side of the caliper was blacked out so that flash rust would not be seen . It was painted with a few strokes of a brush like with the rear drum for the same reason. FYI earlier style front calipers 65-67 were plated for that reason.
« Reply #5 on: August 26, 2014, 09:31:53 PM »
Don't recall any special prep on the calipers for 69 - so bare cast steel with fresh looking machined surfaces. Possibly the black out as Bob described. Dichromate bleeders, galvanized shield (though they are not in the picture below :( , phosphate brake pad retainers, slide pins/bolts dark as are shield mounting bolts. Can't recall this moment if the brake line bolt should have a red dye finish  ::)
Hope this helps - please ignore the paint marks on the spindle. They likely don't apply to your application
« Reply #6 on: August 26, 2014, 09:45:50 PM »
Thanks for the help everyone !!
Dearborn 6/69
