Author Topic: Replace all ruber??  (Read 1612 times)
Offline ptosborn1111
Replace all ruber??
« on: August 24, 2014, 09:03:38 AM »
I may have posted this question previously but couldn't find and do not remember.
Forgive me if the terminology is incorrect as well.
I will have to replace most if not all of the rubber grommets and bushings in front steering and front spring mounts. Some of this stuff has already been replace with aftermarket parts.
Remember, this is a concourse trailored 65', and the question is..... Does anyone (like NPD or the such) make acceptable replacement pieces for this part of the restoration?
Pat
65' Fastback (42k mile car) VIN 5F09A718971
A code 289/4 speed
Body 63A
Color K
Trim 26
Date 07S
DSO 41
71' Boss 351 (Grabber yellow, 2nd owner, 32k miles)
71' Boss 351 (Bright red, 2nd owner, 56k miles)
67' RS/SS 350 Camaro (Butternut yellow project)
Re: Replace all ruber??
« Reply #1 on: August 24, 2014, 04:44:04 PM »
There are some rubber suspension bushings that are not available as an acceptable substitute. The ones that go between the Pitman arm/Idler arm and the center link is one that comes to mind, C4ZA-3A196-A. Virginia Classic has one that fits but is not exact. The tie rod end rubber bushings with the metal ring at the bottom are close, you need to remove the "C5ZZ-3332-A" part number that on the rubber to get closer to the factory one. The seal over the ball joints is another problem area and I don't have the original part number, just the replacement - C7OA-3A105-A.
What else?
« Reply #2 on: August 24, 2014, 11:49:34 PM »
Exactly! ;) ;) I know the ball joint boots are a C-7 which is not right. I have a line on the C-4 boots but as usual am concerned with the rest. The bushings are my question. I can search these out as we go along and suffer the deduction until I find good replacements. I need these, if anyone knows (Jim). The rubber is a problem along with any other steering parts (I mean all metal and rubber) if anyone can help.
I want my deductions to be here and minimal as I progress. Hate to have the wife to be my worst critic!
HELP!
Pat
A code 289/4 speed
Body 63A
Color K
Trim 26
Date 07S
DSO 41
