Author Topic: Original Starter Solenoid Rebuild?  (Read 3082 times)
Offline s2ms
    • 6S1757 Info
« on: March 24, 2010, 01:10:33 PM »
I know this has been discussed before either here or one of the other forums but can't find it at the moment....
Can an original FoMoCo starter solenoid be disassembled and rebuilt? If so, who can do it?
Dave
Re: Original Starter Solenoid Rebuild?
« Reply #1 on: March 24, 2010, 02:02:40 PM »
Don;t know of anyone that has done it but if I was guessing I think that Max  @ AMK might have been doing them for a period before the reproductions started many years ago
Offline sah62
« Reply #2 on: March 24, 2010, 05:25:56 PM »
I used Precision Power (http://precision-pwr.com/) to restore an original heavy duty starter solenoid.  They were the only company I could find that would/could restore this part, and they did so using original-style rivets so that it came out looking and working as good as new.  I recently heard that they're rates have gone up, but I'd still recommend talking to them if you have a date-coded part that no one else can fix
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #3 on: March 24, 2010, 08:52:57 PM »
Scott will or could they do the regular style with the deep set rivet?
Offline sah62
« Reply #4 on: March 24, 2010, 10:32:08 PM »
I don't know, Jeff.  I didn't ask.  I imagine they could if there's a source for the rivets.
Scott Hollenbeck
Offline SCJSTU
« Reply #5 on: March 27, 2010, 09:07:35 AM »
Scott, great info....can you post a pic?
BTW what is the correct numbers for a 428CJ car?
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
« Reply #6 on: March 28, 2010, 03:46:34 PM »
All the HD ones from the period look to carry the engineering number C9AF-11450-A. Know of three different versions/styles, likely due to different providers or running changes.
Don't forget to look for a good date code while your at it.
As a mention keep an eye out form broken ones (the divider between the posts often get broken) with good numbers and date codes - if your rebuilding one, Then get a newer model and swap bases when you have one rebuilt.
Just a thought - I stopped throwing the broken ones away for this reason
Offline SCJSTU
« Reply #7 on: March 28, 2010, 09:09:04 PM »
thanks guys...
Offline s2ms
    • 6S1757 Info
« Reply #8 on: March 29, 2010, 02:34:53 PM »
Thanks for the info Scott. I just spoke with a guy at Precision Power and he said they still do it using OE style deep set rivets. Said the price would typically be $125-250 depending on how much needed to be done.
