Author Topic: Anyone with an X code have pics of the rear axle?  (Read 965 times)
Offline Oz390
« on: August 16, 2014, 07:13:04 PM »
Trying to determine if the configuration of the brake lines/breather below is correct.  Dearborn X code, May 68 build.  The configuration is called out in some references as correct for a 428/427 (427 cougar only) with manual and staggered shocks.  No mention of the X specifically in any, but as an odd-man-out-engine, left out of a lot of discussions.  As a 390 C6 with no staggered shocks does not line up with info I am seeing.  OEM leafs, date on diff fits, proper tag that matches car, so it does not appear that his would have been swapped, but can not be proven.
Anyone out there with an X code and shots of this detail for comparison?
« Last Edit: August 16, 2014, 07:21:28 PM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
