Author Topic: 1969 differential carrier / pumpkin filler plug paint mark findings  (Read 1287 times)
Offline Aussiemach
  • Silver Level Subscriber
Just some observations while cleaning with evaporust.
The area around the filler plug had extra red oxide primer paint on it. Looks like the filler plug was dipped in yellow paint then screwed into the housing. The paint would have acted as a sealant and also showed that the differential was filled with oil ?
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Re: 1969 differential carrier / pumpkin filler plug paint mark findings
« Reply #1 on: August 16, 2014, 08:05:22 PM »
Correct oil level is just below the hole and plug some not sure if what you found was suppose to work as a sealant.
Just a thought - thanks for sharing, makes you wonder though
Offline Aussiemach
« Reply #2 on: August 16, 2014, 09:15:46 PM »
I thought of the paint for sealant because it was common practice here many years ago to seal galvanised water pipes threads with paint
« Reply #3 on: August 17, 2014, 08:13:35 AM »
 :o Yeah, those were the days (YIKES) ...but we all turned out OK. (if we didn't eat paint chips anyways)
