Author Topic: Sun X  (Read 4118 times)
Sun X
« on: August 13, 2014, 10:53:04 PM »
     The rear window glass in my 9/19/68, non AC, Metuchen fastback is clearly marked Sun-X.  My impression was that the Sun-X glass was for AC cars ?  Was the Sun-X glass clear or tinted for 69.  Thanks,  Brian
Offline GT500KR
  • Charlie Ping
Re: Sun X
« Reply #1 on: August 13, 2014, 10:57:25 PM »
I believe "Sun-X" is tinted glass. I have never seen otherwise. Usually positioned under the "Carlite" or "Ford" logo.
It was an option separate from A/C most years. I ordered a new Mustang, and an F-150 that way.
« Last Edit: August 13, 2014, 11:00:30 PM by GT500KR »
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline Texas Swede
Re: Sun X
« Reply #2 on: August 13, 2014, 11:44:14 PM »
As far as I know all 65-68 Fastbacks had Sun-X rear windows. Probably also on
69 and 70 Sport Roofs.
Texas Swede
Re: Sun X
« Reply #3 on: August 14, 2014, 12:10:47 AM »
I should add that all the glass in my car is marked Sun-X except the clear windshield.  Brian
Offline Andrew@MagMustangs
    • MagMustangs
Re: Sun X
« Reply #4 on: August 14, 2014, 12:42:31 AM »
All Fastback Rear Glass through 1973 was SUN-X because of the larger area of glass. All SUN-X glass is tinted light green in color. As far as I know, SUN-X was not mandatory with A/C but it was highly recommended. And Yes, it was available on cars without A/C.
Offline GT500KR
  • Charlie Ping
Re: Sun X
« Reply #5 on: August 14, 2014, 01:54:16 AM »
What kind of markings / date codes have you got on your windshield Brian? Having a clear windshield if all the other glass is Sun-X with date codes that make sense would not be typical. I suspect that the windshield was changed at some point.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
Re: Sun X
« Reply #6 on: August 14, 2014, 10:42:22 AM »
     The side and back glass does seem to have a very subtle greenish tint, glass is dated 8G or 8H and is marked CARLITE Sun-X.  The windshield is clear, marked CARLITE-Laminated and is dated 8H.  No mention of tinted glass in the Marti report.  Brian
Offline GT500KR
  • Charlie Ping
Re: Sun X
« Reply #7 on: August 14, 2014, 11:10:30 AM »
 In my experiences, I've never seen a car equipped that way. In fact if anything, it's the other way around. It was possible at least in some model years to order just the windshield tinted, or tinted and shaded. Of course it's still possible for it to have been replaced at some point in the past. The year is not incorporated in the date code, so you still had a 1 in 12 chance of matching it!  ;)
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
    • MagMustangs
Re: Sun X
« Reply #8 on: August 14, 2014, 02:03:59 PM »
The Year is incorporated in the date code with 8H being either August 1968 or August 1978. However, Brian's Windshield glass has the correct for 1969 (CarLite) Logo instead of the later CARLITE block letters logo which I believe had been introduced before 1978. Brian, if SUN-X is not mentioned in the Marti nor is your car an A/C car then my personal best guess would be that your side glass has been replaced at some point. It would have been fairly easy for a PO to replace the side glass, more so then replacing the windshield with a date correct original piece. A lot of the 69s had their door glass replaced pretty early on due to the poor design of the glue-in mounting.
« Last Edit: August 14, 2014, 02:06:05 PM by Andrew@MagMustangs »
Offline GT500KR
  • Charlie Ping
Re: Sun X
« Reply #9 on: August 14, 2014, 04:42:35 PM »
Good catch Andrew. Marti report would be very helpful.
Been looking at too many sheet metal stampings I guess lately.
« Last Edit: August 14, 2014, 04:45:34 PM by GT500KR »
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
Re: Sun X
« Reply #10 on: August 14, 2014, 05:09:08 PM »
While window replacement is always a possibility.  Doubtful.  When I stated side glass I meant doors and quarters.  The windows are the OE glue in version and have not been switched for the 70 bolt-ins.  The window tint is very faint in fact barely discernible.  Is there a spot on the build sheet that would be of some help ?  Brian
« Last Edit: August 14, 2014, 05:14:38 PM by Brian Conway »
Re: Sun X
« Reply #11 on: August 14, 2014, 08:59:01 PM »
...............  Is there a spot on the build sheet that would be of some help ?
No the buildsheet does not cover glass installation. Believe glass was already installed by the end of the first half of assembly - prior to the applications of buildsheets
Offline BuckeyeDemon
    • Photobucket Pictures
Re: Sun X
« Reply #12 on: August 20, 2014, 10:36:47 PM »
the backglass in my 69 was tinted.  no other glass was tinted. i don't have AC and nothing mentioned in the invoice.
VIN: 9F02M178303
Build Date: March 31, 1969
1969 Mach 1, Candyapple Red, 351W 4V
Offline andestang
Re: Sun X
« Reply #13 on: August 21, 2014, 02:27:04 AM »
My rear window and both vent windows are marked SUN-X also, but my doors have been changed out at some point from a '70 as it has bolted in windows and the front I had changed a long time ago so I can't say there ether ( wish I knew better back then to pay attention) and my car is also a none A/C.
