Author Topic: Rear Speaker option  (Read 2123 times)
Offline JonnyD
Rear Speaker option
« on: August 10, 2014, 11:49:27 PM »
I'm trying to determine if my 67 Mustang would have come from the factory with the rear speaker, or if this was simply a dealer installed option.  Also, mine has this unique knob under the dash by the parking brake, that is a mono "fader" to balance the sound from the single dash speaker and the single rear deck speaker.  Anyone seen these before?  Pics attached.
Re: Rear Speaker option
« Reply #1 on: August 11, 2014, 02:26:40 AM »
I found fade switch on a loaded 1969 Grande from Metuchen. Junk yard car from SoCal a bunch of years ago. It had a factory AM/FM or AM/8Track according to the buck tag code. I don't recall the rear speaker configuration. I do remember the that switch was installed under the dash, on the right side of the steering column.
« Reply #2 on: August 11, 2014, 06:38:09 AM »
I wonder if that fader switch is factory installed. It may be a dealer installed though. What does the wiring look like?
I recall only one instance of a rear speaker on an AM radio (cannot remember if it was a 67 or a 68) but the fader was a slide over the tuner shaft, outside the radio bezel, factory had left off the plastic do-hickey that holds the "balance" knob in a stationary posision, and put the fader in there.
Richard
« Reply #3 on: August 11, 2014, 08:12:44 AM »
Dealer or aftermarket IMO.  Have never seen one, read about one, nor seen Ford documentation about it.
Keep in mind that Ford documentation was often "generous".  Consider the number of 67's sold with speed control, yet there are several pages dedicated to it in the shop manual.  Then again there is the "W" code 68 documentation for something planned but never sold.  This leads me to believe that documentation came first (and sometimes the equipment came second...or never).
Perhaps it was a pre-production or very early production model that was modified by Ford for testing and evaluation.  I would expect a very very low VIN for that.
How about some pictures of the wiring from the trunk side, and if possible under the dash.  That could also be telling.
Offline GT500KR
  • Charlie Ping
« Reply #4 on: August 11, 2014, 08:59:06 AM »
+1 on that
 Ergonomically, that's a bad spot for the switch. IMHO I don't think Ford would have mounted it directly above the parking brake handle. Seems like it would scrape your hand whenever the brake was applied, as well as being awkward to manipulate.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline mtchstng65
« Reply #5 on: August 11, 2014, 09:43:42 PM »
I know there was a reverb available on 65 or 66s that had a rear speaker and a fader. The reverb was a rectangular box looking thing.
1965 Fastback, 1966 Fastback, 1986 GT Hatchback (Unrestored), 2003 Mach 1,
2008 Shelby GT500,
641/2-66 Concours Mustang MCA Certified Judge & 1965-1966 Shelby MCA Certified Judge
www.showmemustang.com
« Reply #6 on: August 11, 2014, 10:05:15 PM »
Aftermarket - both the switch  and speaker grill do not look like  Ford items from that year so likely not a dealer option as defined by any of the judging organizations.
