Author Topic: Accelerator pedal  (Read 1087 times)
Offline Angela
Accelerator pedal
« on: August 10, 2014, 02:04:14 PM »
I don't fully understand it, but page 41 of the Chassis Assembly manual says:
  "Adjust rod 9A702 to obtain this idle pedal height setting with carb choke fully opened. This measurement is to be taken from the flat section of the dash panel outboard of pedal 10.5" line. The panel changes inboard of this height."
It's the 10.5" verbiage I don't understand.
Regardless, I strongly suspect my gas pedal is too close to the carpet; it sits noticeably closer to the carpet than the brake pedal. ---> Is that common, or are the brake and accelerator pedals supposed to be at about the same height off of the carpet??? Pictures would help, if anyone could provide them. Or, a measurement from the carpet to the gas pedal would be great as well.
The assembly manual specifies 4 to 4.5" height above the carpet, which seems WAY to high IMHO. My pedal is ~2" above the carpet right now and I question whether it's fully opening the carb (it's close, very close, but I cannot be certain it is fully opening).
Help?
One more thing...... if I need to bend the accelerator linkage, how do I do this without removing it from the car? I truly don't believe I could remove it with the engine installed (390... no space to get at the bolts). I have the 9A702 linkage at the carb adjusted to the max.... any further and the accelerator rod hits the engine side of the firewall when the carb is at idle.
« Last Edit: August 10, 2014, 02:07:57 PM by Angela »
Re: Accelerator pedal
« Reply #1 on: August 10, 2014, 02:44:00 PM »
Are you sure you have the right bell crank?  Check out http://www.concoursmustang.com/forum/index.php?topic=8861.msg51709#msg51709
Here are some pictures of unrestored units.
Offline Angela
« Reply #2 on: August 10, 2014, 03:14:28 PM »
Thanks for the pictures John. I've fairly certain the bell crank, it's the one I removed from the car during dis-assembly and it has the correct automatic kick-down bracket.
From your pictures, it appears two of the three situations show the gas pedal closer to the floor than the brake pedal. The third pic looks like they are set at nearly identical heights.
« Reply #3 on: August 10, 2014, 07:12:15 PM »
Regarding the height of the one that looks the same, yes I was surprised to find that.  A few more.  Looks like the same height one is an anomaly.
