Author Topic: Convertible pump and rods - date code - year of car  (Read 1632 times)
Offline hkopp
« on: August 08, 2014, 10:44:08 AM »
I bought a conv pump and rods 25 yrs ago at an auction, and was going to use them on a custom application.  I didnt know they were mustang parts at the time, but the appear to be off of a 65 mustang according to one website i found.  Hoping someone can tell me what they are from, just in case they are worth something I'd rather not use them for a non mustang project.
« Last Edit: August 08, 2014, 10:55:01 AM by hkopp »
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
Offline Oz390
Re: Convertible pump and rods - date code - year of car
« Reply #1 on: December 03, 2014, 04:29:51 AM »
Not sure on the pump, and asked a similar question on the rams a while ago.  My rams had a "6K" or "K6" stamped in the base, which I assumed was a Oct 66 date code.
http://www.concoursmustang.com/forum/index.php?topic=7875.0
On the pump based on the fill nut on the end looks to be a mid 70's to late 80's model.  The originals (used 65 thru the early 70's) had a fill plug on the side, can't tell from the photo but does not appear to be one there, only on the end. Most were not Mustang specific and used in a lot of different lines.
Some info and photos that may help here...
http://www.topmotorrepair.com/
On the rams I think that they are also "later" ones as I have seen mention of early ones with nylon/plastic bushings embedded in the pivots, yours do not appear to have these which would align with the (apparently) later pump.
Appears to be a mystery area, as details of convertible parts are not generally noticed in judging standards.
HTH
8R03S : 76A I 2A 15M 72 5 U
Offline TLea
« Reply #2 on: December 03, 2014, 09:16:12 AM »
Not really mystery just not often judged as they aren't seen other than clevis pins, upper bushings. Definately not from vintage mustang. I believe they are from later (69+) full size car
