Author Topic: Alternator/Air Conditioning Idler pulley positions  (Read 4687 times)
Offline Herman
« on: August 07, 2014, 06:19:42 PM »
Hello All,
I am looking for a some engine bay photos which show Alternator/Air Conditioning Idler pulley positions on 66 which has Power Steer & Air Con.  Any help would be greatly appreciated.
Thanks in advance
Herman
Washing, polishing and cleaning stuff some more in an attempt to retain that 'Golden nugget'
Re: Alternator/Air Conditioning Idler pulley positions
« Reply #1 on: August 07, 2014, 10:12:54 PM »
V8?
Offline Herman
« Reply #2 on: August 07, 2014, 11:38:22 PM »
Sorry forgot to include its an A Code GT, please note I am try to keep the car close to original as possible.
« Reply #3 on: August 07, 2014, 11:56:54 PM »
................... please note I am try to keep the car close to original as possible.
Would not expect anything else here on this forum ;)
Hope one or more fits you needs. Not an easy area to get a clear picture of. If you need a specific detail please ask and I'll start looking
Pictures are from a late 66 San Jose  non- Thermactor, AC and PS V8 (12K miles) . Last picture is from an early San Jose car  equipped the same way
« Last Edit: August 08, 2014, 08:08:47 PM by J_Speegle »
Offline Herman
« Reply #4 on: August 08, 2014, 01:16:00 AM »
Thanks Jeff really appreciate the photos and all the advise, my car is an 15 October 65 SJ built GT Convertible.
Also noticed the Coil is positioned verticially on the front of the block, is the correct position. As l mine is located horizional near the carby.
Herman
« Reply #5 on: August 08, 2014, 01:25:58 AM »
It appears to be a difference between 289 C and A codes and if they were equipped with thermactor.
With thermactor there is no room at the front of the engine to mount the coil so it was moved to the intake - passenger side.
Offline Herman
« Reply #6 on: August 08, 2014, 02:14:21 AM »
Thanks for clarifying
Offline lancelot66
« Reply #7 on: August 08, 2014, 12:24:21 PM »
Jeff,
This brings up a lingering question I have specific to your photo of the coil, mounted verticle, on the front of the passenger side head. When I relocate mine back to its original location on top of the intake (along with the original thermactor setup installation), does the engine code decal still get placed across the coil strap?
Not sure what SJ did here (our's is a 1-6-66 dated car). Have never been able to locate any evidence to support, one way or the other so far...
Thank you!
-Lance
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
« Reply #8 on: August 08, 2014, 07:57:23 PM »
Jeff,
Thank you!
-Lance
Good question and I don't believe its a San Jose thing since the decals were applied at the Cleveland engine plant. This helped in identifying the engines for shipment as well as at the car assembly plants once they arrived. Example would be that room full of engines recently posted in the members only area or the picture of the room full of engines at Holman & Moody
Let me look around and see if there are any examples of where they might have applied that ID decal on Thermactor equipped cars - It's a one year thing since in 67 they were moved to the valve cover on some small blocks (another can of worms) , timing cover on 6 cylinders and the head on big blocks
« Last Edit: August 08, 2014, 07:59:29 PM by J_Speegle »
Offline lancelot66
« Reply #9 on: August 08, 2014, 08:03:38 PM »
Sounds good Jeff. Sure do appreciate the effort. One of those items I've never been able to verify. That picture got a long look too. I can study those photos for a long time and still read posts later of those finding something I didn't see...incredible.
VR/
-Lance
SJ Build Date: 1/6
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #10 on: August 08, 2014, 10:15:26 PM »
Here's a cartoon drawing I did for my car.  It's a MAR 66 Metuchen C-Code with AC/PS and without thermactor, if that helps.
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #11 on: August 08, 2014, 11:23:09 PM »
Nicely done    :)
Offline bryancobb
  • 2009 Ridn' Around
« Reply #12 on: August 09, 2014, 07:52:29 AM »
Thanks...It IS my day-job though, so you would expect no less ;)
66 Metuch Conv
« Reply #13 on: August 09, 2014, 07:58:18 PM »
Of course not - but IMHO still worthy of a mention :)  and a thanks
Did the same for a few years on the side - saw not problem with offering the compliment. Sure your choice of software makes it a bit easier than my choices.
« Last Edit: August 09, 2014, 08:07:41 PM by J_Speegle »
Offline Herman
« Reply #14 on: August 10, 2014, 05:57:06 PM »
Thanks Bryan really appreciate all the help
Herman
