Author Topic: Interior Door handle or window crank plastic washers  (Read 1695 times)
Offline Angela
« on: August 06, 2014, 12:09:09 AM »
Looking for two good original washers which locate between the interior door handles and the door panels. Application is 1967.
Offline Angela
Re: Interior Door handle or window crank plastic washers
« Reply #1 on: August 07, 2014, 09:38:00 AM »
I think, but am not certain, the part number is C5AZ-6223370-A
Anyone have one or two of these laying around?
« Reply #2 on: August 07, 2014, 10:51:07 AM »
I'm sure I have some extras but can't confirm until the weekend.
« Reply #3 on: August 09, 2014, 07:45:54 PM »
I found two types, one with a 15/32" Dia hole and the other with a 3/4" Dia hole.  Other dimensions and characteristics are the same.
I have four with the small hole, which can be made into the larger if needed.  I only found two with the large hole...so far.
The body engineering manual calls for:
1. C4SB-6323370 quarter window.  Two per car (coupe/convertible)
2. C5AB-6223370 for door window and handle.  Four per car.
Interesting that the number changes from 632 to 622.
So I need to find some door and window handles to see which, if any, I can part with.
« Reply #4 on: August 10, 2014, 09:16:27 AM »
Correction on the part number - the "core" number is 23370.
Also the correct description is "Plate - Window Regulator Handle".  Used for door handles also...
The 75 MPC says...
C3AZ 6223370-A 65 Door before 3/8/65 Qty 4
C5AZ 6223370-A 65-67 Door after 3/8/65 Qty 2 or 4 (not sure why 2 would work, unless they come in a package of 2?)
  The body assembly manual calls for C5AB 622370-A Qty 4
C4SZ 6323370-A 65/57 Quarter Qty 2
  The body assembly manual number and quantity match
C8AZ 6223370-A 68 Nylon 3/4"I.D. x 1-9/16" O.D. Qty 2 to 6
C9ZZ 6523370-A 69/ Bright finish 3/4"I.D. x 1-13/16"O.D. x 3/8" thick Qty 2
The diagrams are not very helpful.  By appearances the large I.D. (3/4") is used on the doors (window and door handles) while the smaller I.D. is used on the quarter window.  There are no part numbers specified on the drawings, only the core 23370 number.
Based on this for a fastback (assumption on my part) you would need four of the larger I.D. plates.
