Author Topic: Late '67 Mustang 390 Fuel Line  (Read 1580 times)
Offline JIMeast
« on: August 04, 2014, 03:05:53 PM »
I have a late '67390 w/Holley 4V and am trying to find out the diameter for the pump-to-carb fuel line.  I am assuming it is 3/8, but do not know for sure.
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
Re: Late '67 Mustang 390 Fuel Line
« Reply #1 on: August 04, 2014, 07:42:43 PM »
My 4-27-67 built 390 4V is 3/8.
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
« Reply #2 on: August 04, 2014, 09:50:51 PM »
67's are typically 5/16 not 3/8. 3/8 is typically 68.
« Reply #3 on: August 04, 2014, 09:55:12 PM »
Mike ,your restored car if it has 3/8's fuel line most likely had the line changed for the better flowing 3/8 line during it's restoration. it is a common practice. Most don't notice. the corresponding fuel pump will have 5/16 inlet too.
Offline mikelj5S230
« Reply #4 on: August 04, 2014, 10:22:49 PM »
Thanks Bob!  As expected, you are correct.  I rechecked it with my 5/16th wrench, and sure enough it fits tightly over the line, the 3/8th I tried first has a looser fit I didn't notice at first glance. :)
Offline JIMeast
« Reply #5 on: August 05, 2014, 09:24:01 AM »
Thanks for the feedback, for some reason, I have been under the impression for some time that the fuel line from tank to carb went to 3/8 in late '67 for a 390 build.  I saw the word "typically" used in Bob's response.  My car was built June 26th, '67 in SJ.  Just about as late as they come.  Was the line diameter changed over to 3/8 for the '68 model year in 390's?
« Last Edit: August 05, 2014, 09:26:17 AM by JIMeast »
« Reply #6 on: August 05, 2014, 11:35:04 AM »
I have learned to use the would "typically" so as to account for the inevitable anomaly that may happen. I have heard stories over the years of the very late changeover but have never personally seen it or seen any documentation to support it. I suspect like many of these unsupported anomaly stories that the late 67 3/8 changeover is simply a justification for a non stock modification.  I have seen late June 67 cars and all I have examined had 5/16. Not that it isn't in the realm of possibility but unlikely at this point .FYI all of the fuel lines were changed over to 3/8 in 68 from 6cyl to 428CJ.
« Last Edit: August 05, 2014, 11:37:05 AM by Bob Gaines »
