Author Topic: Need pics of 67 Fastback trunk rod setup  (Read 1136 times)
Offline 1965GTFB
« on: August 01, 2014, 07:54:07 PM »
Need to see pics of a 67 fastback trunk rod.  Specifically the pass side end of the rod and the bar/piece that goes from the rod to the solid pat of the hinge.  We are reassembling and using the parts that were on the car but it had been monkeyed with having a carriage bolt and a nut welded on.  The flat bar from the tension rod to the hinge that acts as the stop when open(that part is working fine) hits the hinge just before the trunk is all the way closed.  Wondering if the straight flat bar is not the original correct piece.
Re: Need pics of 67 Fastback trunk rod setup
« Reply #1 on: August 01, 2014, 10:06:52 PM »
You didn't include the plant or month so hope this applies - all from San Jose examples. Hope it helps
